I have a problem with upgrade my Owncloud server 9.0.3 to 9.1.0 :
# sudo -u apache php /var/www/owncloud/occ upgrade
Set log level to debug
Checking whether the database schema can be updated (this can take a long time depending on the database size)
Done
24/24 [============================] 100%
Checked database schema update
Checking updates of apps
Checking whether the database schema for <activity> can be updated (this can take a long time depending on the database size)
Done
2/2 [============================] 100%
Checking whether the database schema for <dav> can be updated (this can take a long time depending on the database size)
Done
10/10 [============================] 100%
Checking whether the database schema for <files_antivirus> can be updated (this can take a long time depending on the database size)
Done
Checking whether the database schema for <files_sharing> can be updated (this can take a long time depending on the database size)
Done
1/1 [============================] 100%
Checking whether the database schema for <files_trashbin> can be updated (this can take a long time depending on the database size)
Done
Checking whether the database schema for <notifications> can be updated (this can take a long time depending on the database size)
Done
Checking whether the database schema for <user_ldap> can be updated (this can take a long time depending on the database size)
Done
3/3 [============================] 100%
Checked database schema update for apps
Updating database schema
Updated database
Updating <user_ldap> ...
Error: Class 'OCP\Backgroundjob' not found in /var/www/owncloud/apps/user_ldap/appinfo/update.php:23
Stack trace:
#0 /var/www/owncloud/lib/private/legacy/app.php(1192): include()
#1 /var/www/owncloud/lib/private/Updater.php(374): OC_App::updateApp('user_ldap')
#2 /var/www/owncloud/lib/private/Updater.php(251): OC\Updater->doAppUpgrade()
#3 /var/www/owncloud/lib/private/Updater.php(150): OC\Updater->doUpgrade('9.1.0.15', '9.0.3.2')
#4 /var/www/owncloud/core/Command/Upgrade.php(290): OC\Updater->upgrade()
#5 /var/www/owncloud/3rdparty/symfony/console/Command/Command.php(259): OC\Core\Command\Upgrade->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\Cons oleOutput))
#6 /var/www/owncloud/3rdparty/symfony/console/Application.php(844): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\O utput\ConsoleOutput))
#7 /var/www/owncloud/3rdparty/symfony/console/Application.php(192): Symfony\Component\Console\Application->doRunCommand(Object(OC\Core\Command\Upgrade), Object(Symfony\Component\Console\Input\ArgvInpu t), Object(Symfony\Component\Console\Output\ConsoleOutput))
#8 /var/www/owncloud/3rdparty/symfony/console/Application.php(123): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Out put\ConsoleOutput))
#9 /var/www/owncloud/lib/private/Console/Application.php(146): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\Con soleOutput))
#10 /var/www/owncloud/console.php(94): OC\Console\Application->run()
#11 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
Someone he already encountered this problem?
thank a lot!
Operating system: Red Hat Enterprise Linux Server release 7.2 (Maipo)
Web server: Apache/2.4.6
Database: mariadb 5.5
PHP version: PHP 7.0.9 (cli) (built: Jul 21 2016 15:42:36) ( NTS )
Updated from an older ownCloud or fresh install: 9.0.3
