1.Using a link to download on cell phone, when you hit play, the preview of the video are to big!
2.
3.
Tell us what should happen i want to give a max size to the preview to fill the screen properly
Tell us what happens instead open big (i guess 1920x1080) and crop, u can see a part of the video
Operating system: raspbian
**ownCloud version:10.5.0 (stable) (see ownCloud admin page)
**Updated from an older ownCloud or fresh install:Fresh
**Are you using external storage, if yes which one:no local/smb/sftp/…
Are you using encryption: yes
I m very new with owncloud and raspbian… i just want to know witch archive i need to modify to leave in fixed size the preview of the video to download! Thanks! I leave a link, if you want, you can open on cell phone push play and see the video size up and crop in the screen! Thanks again! http://trimzero.ddns.net:8086/index.php/s/CGg3GAJLnn3lodq sorry if i in the incorrect section!
