we have setup an ownCloud environment with version 10.0.7. We tried to run commands using the occ tool, which runs perfectly fine in our other environments. We do recieve the following error and I don’t understand what went wrong:
www-data @ 3da81882081f: ~/owncloud # php occ
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'owncloud.appconfig' doesn't exist in /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:104
Stack trace:
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php(104): PDO->query('SELECT * FROM `...')
#1 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(852): Doctrine\DBAL\Driver\PDOConnection->query('SELECT * FROM `...')
#2 /var/www/owncloud/lib/private/DB/Connection.php(187): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#3 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#4 /var/www/owncloud/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/owncloud/lib/private/AppConfig.php(301): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/owncloud/lib/private/AppConfig.php(80): OC\AppConfig->loadConfigValues()
#7 /var/www/owncloud/lib/private/AppConfig.php(278): OC\AppConfig->getApps()
#8 /var/www/owncloud/lib/private/legacy/app.php(1000): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/owncloud/lib/private/Server.php(436): OC_App::getAppVersions()
#10 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('MemCacheFactory')
#12 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('MemCacheFactory')
#13 /var/www/owncloud/lib/private/Server.php(1195): OC\ServerContainer->query('MemCacheFactory')
#14 /var/www/owncloud/lib/private/Server.php(593): OC\Server->getMemCacheFactory()
#15 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#16 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('AppManager')
#17 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('AppManager')
#18 /var/www/owncloud/lib/private/Server.php(1411): OC\ServerContainer->query('AppManager')
#19 /var/www/owncloud/lib/private/legacy/app.php(346): OC\Server->getAppManager()
#20 /var/www/owncloud/lib/private/legacy/app.php(110): OC_App::getEnabledApps()
#21 /var/www/owncloud/lib/base.php(577): OC_App::loadApps(Array)
#22 /var/www/owncloud/lib/base.php(994): OC::init()
#23 /var/www/owncloud/console.php(64): require_once('/var/www/ownclo...')
#24 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
#25 {main}
