I’m trying to set up S3 storage to work with OC so I set up a bucket and generated some keys and following the OC documantation for S3 setup, I entered the required fields but the little check box shows as red. I’ve tried to find a thread in which my issue is solved but I can’t find the solution. Everything I try results in a red status box. I’ve never worked with S3 storage before so I’m new to this. Could someone tell me what I might need to do to figure out how to get this working?
when posting a new topic i’m getting the following template shown which seems got omitted by you. Maybe you can fill out this template so other users are able to help you?
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
