I have got installed the owncloud server on my debian server some time ago.
It's not my first installation but the error does appear every time.
If I upload bigger files, I got the following errormessage:
The config is onfigured correcty, so I can normally upload big files
Unfortunately I have got some integraty errors since the beginning of the installation:
Do you have any idea how to solve the problem?
- Upload bigger files via the web gui
The files will be uploaded correctly
I receive an error message while uploading big files.
Operating system:Debian GNU/Linux 8
Web server: apache
Database: mysql
PHP version: 5.6.31
ownCloud version: 10.0.2.1
Where did you install ownCloud from: https://owncloud.com/de/download/
Admin Config Report
Deleted files
Federation
Provisioning API
Share Files
Update notification
Versions
Collaborative tags
Comments
First run wizard
FTP storage support
Gallery
GpxPod
Mail Template Editor
Market
Notifications
Onlyoffice
Video player
**Are you using external storage, if yes which one: no
Are you using encryption: no
Browser: Google Chrome
