- Install Guests App via Market
- Invite new guest user via a folder sharing (e-mail address)
Guest should be invited and have access.
Error message: Fehler beim Teilen (Issue during sharing)
Event Log:
{“reqId”:“WwwyQ6H0Qnx8j2mfszfeqwAAAAc”,“level”:3,“time”:“2018-05-28T16:45:55+00:00”,“remoteAddr”:“192.168.178.21”,“user”:“184B6324-0EE1-4910-8270-7DF9AC2746F5”,“app”:“no app in context”,“method”:“PUT”,“url”:"/index.php/apps/guests/users",“message”:"User backend OC\User\Database is returning home: /kpcloud_data/owncloud/data//grimbi@icloud.com for user: grimbi@icloud.com which differs from existing value: "}
CentOS 7 Lates patches installed
Apache
MariaDB
10.0.8.5
Updated from Owncloud 9
Repo
"system": {
"instanceid": "ID",
"trusted_domains": [
"domain1.com",
"domain2.de",
"private IP"
"datadirectory": "\/cloud_data\/owncloud\/data\/",
"overwrite.cli.url": "https:\/\/domain1.com\/",
"dbtype": "mysql",
"version": "10.0.8.5",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"mail_smtpmode": "smtp",
"loglevel": 2,
"updatechecker": false,
"maintenance": false,
"ldapUserCleanupInterval": 60,
"versions_retention_obligation": "disabled",
"mail_smtphost": "***REMOVED SENSITIVE VALUE***"
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- guests: 0.5.0
- market: 0.2.4
- notifications: 0.3.3
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
- user_ldap: 0.11.0
Disabled: - encryption
- external
- files_videoviewer
- theme-example
- user_external
no
no
LDAP
