I have a problem: I try to reset user password (user side with internet browser), I get reset link by mail, after clicking I get error message: Could not reset password because the token does not match.
I have no idea how to fix it. Any help?
Best regards, nason
i think the “oC Internals” category chosen to post this topic was a little bit misplaced, “Server-Help” probably is better fitting here .
If i’m creating a new thread in this category i’m getting the template below presented. Maybe you could fill out the information asked within it so people are better able to help you?
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
