Can't resharing
9.0.1
At your external storage mount, you should normally see a point to enable sharing:
https://doc.owncloud.org/server/9.0/admin_manual/configuration_files/external_storage_configuration_gui.html#mount-options
Just to avoid confusions and re-reporting of already fixed bugs, could you update to the latest version 9.0.4?
New option for the ownCloud admin to enable or disable sharing on individual external mountpoints (see Mount Options). Sharing on such mountpoints is disabled by default.
from https://doc.owncloud.org/server/9.0/admin_manual/release_notes.html#changes-in-9-0
and
The drawbacks are that sharing is disabled when this mechanism is in use
thx for help. RLy work dat help
