- Add a external storage S3 compatible to CEPH SD Storage
- Import SSL root certificte
- Get red button and message of error
- When I execute the following command " sudo -u wwwrun php occ files_external:verify 2", I get this error:
- status: error
- code: 1
- message: Aws\Common\Exception\TransferException: [curl] 6: Could not resolve host: mybucket.mydomain.com [url] https://mybucket.mydomain.com
Get the green button on the external storage and Access the files in it.
I get the red button and the error by occ commands
Linux SUSE Linux Enterprise Server 12 SP3
Apache/2.4.23 (Linux/SUSE)
Server version: 10.0.30-MariaDB SLE 12 SP1 package
PHP 7.1.30
10.2.1.4 Community
Fresh install
From community
No errors have been found
