Server connection
nothing happens when trying to upload files from Iphone or Ipad - it only says - waiting for server connection or permission error - and looking for this error messinges there are no answers in help-documents and no answers anywhere else - this is a very difficult app to use.
I can see my uploaded files from my desktop everywhere - so there is some kind of connection to the server even in the Iphone.
Hi, can you provide more information about your setup?
What kind of information do you need /Anders
The ones that are in the form that appears when you open a topic here
There is nothing that appear when I opened this, or I don't know how to get hold of that info now.
Anyway, I am working on a Mac, latest OS, and also the latest OS on the Iphone. And I downloaded and installed the latest version of OwnCloud that I could find. My hosts server is a Red Hat Linux. And as far as I can see, it is working alright on the desktop.
I have tried different WebDav apps on the Iphone, but I didn't succed to contact Owncloud with them - and I will also say that the files that is uploaded to Owncloud from desktop are available on the Iphone - but I can't upload anything to Owncloud from my Iphone - maybe I'm just doing it the wrong way - but I have tried several times and all I get is some errormessages "Permission error admin @ konstkalendern.com/cloud/owncloud/... (I can't read the whole message). When I click on this message there is a dialog box saying "You don't have persmission to upload to this folder" and I can choose folder. But none of my folders have the right permissions.
Sometimes I get another message saying: "Not available on this device". And no more!
/Anders
2.
3.
Are you using external storage, if yes which one: local/smb/sftp/...
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
I don't know where to send you log file and config report - they are to large to copy in here /Anders
Okay, can you fill in the information you can fill in?
That would be a good start
