we are using owncloud for some years successfully. One user has now a strange problem:
A large file was shared between 2 users. The original file was delete. So the second user has a shared copy within his file space. Now the user has moved the file from Owncloud to the local disk. The file is gone, but the system is reporting the following error:
{“reqId”:“JS3bdzwvo05dnhLHpeky”,“remoteAddr”:“X.X.X.X”,“app”:“webdav”,“message”:“Exception: {“Message”:“HTTP\/1.1 503 Storage not available”,“Exception”:“Sabre\\DAV\\Exception\\ServiceUnavailable”,“Code”:0,“Trace”:”#0 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(79): OCA\\DAV\\Connector\\Sabre\\ObjectTree->getNodeForPath(‘04 - Pal Pal Ha…’, 0)\n#1 [internal function]: Sabre\\DAV\\CorePlugin->httpGet(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#2 \/var\/www\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(459): Sabre\\Event\\EventEmitter->emit(‘method:GET’, Array)\n#4 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#5 \/var\/www\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(61): Sabre\\DAV\\Server->exec()\n#6 \/var\/www\/owncloud\/remote.php(164): require_once(’\/var\/www\/ownclo…’)\n#7 {main}",“File”:"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/ObjectTree.php",“Line”:159,“User”:“USERNAME”}",“level”:4,“time”:“2019-01-28T07:45:22+00:00”,“method”:“GET”,“url”:"/remote.php/webdav/04%20-%20Pal%20Pal%20Har%20Pal-(MyMp3Singer.net).mp3",“user”:“USERNAME”}
It is not possible to upload the file again (there is an error “file size different”).
Any idea ?
ubuntu 14.04.05 LTS
apache 2.4.7
mariadb 5.5.61
9.1.8
