SHGetKnownFolderPath entry point not found
This post was flagged by the community and is temporarily hidden.
if i’m understanding the following in https://owncloud.org/download/#owncloud-desktop-client-windows correctly:
System requirements: Windows 7+
the ownCloud team had decided to drop support for such an outdated, insecure and end-of-life operating system like Windows XP.
If you have complains about this then i think it is probably better to contact the ownCloud team directly via https://github.com/owncloud/client/issues as i’m not sure if these guys are reading this. :confused:
i just have seen that i have missed this question:
I don’t think that they have such kind of compatibility table. The only notice about this i had found in the documentation is the following:
https://doc.owncloud.org/server/10.3/admin_manual/installation/system_requirements.html#clients-and-mobile-apps
If you think there should be such a compatibility table maybe you can ask for one at https://github.com/owncloud/docs/issues ?
