Am using OwnCloud version 10
Ubuntu 20.04
Nginx
All working fine
I copied data into the user folder inside owncloud/data/some_user
But when I login as some_user, inside the page I don’t see the moved data
Do I have to run some synchronisation via command line if I manually move data files on server ?
You shouldn’t do that in general. Use the web frontend or any WebDAV-aware client for uploading files.
For any maintenance tasks you can use ./occ files:scan --all
EDIT: BTW,
I hope you meant owncloud/data/some_user/files
@alfredb actually these were backup files as I migrated the system to latest version. So it was easier to just use mv command and move it into the data folder.
Thanks for the solution once again
system
Closed
September 27, 2021, 8:25am
4
