Hi all,
just to avoid any trouble I would like to know if a direct upgrade of my OwnCloud from 10.0.2 to 10.0.9 is supported. Or do you I have to upgrade with all steps like 10.0.2 => 10.0.3 … => 10.0.9? And when the small steps are needed, where can I find the older versions?
Thanks for your support.
Regards, Joshua
Operating system: OpenSuse Leap 42.3
Web server: Apache 2.4.23
Database: MySQL Ver 15.1 Distrib 10.0.35-MariaDB, for Linux (x86_64) using readline 5.1
PHP version: PHP 7.0.7 (cli) ( NTS )
ownCloud version: 10.0.2.1
