I try to add a public link to my owncloud server via the webUI and want to make this link editable. I saw in the user manual, that there should be an checkbox to do so, but on my server this box is not showing up. Did I disable this feature somehow?
I want to share a folder
Go to public link
Create public link or Edit public ling
There should be a checkbox “Allow Editing”
Only Checkbox for “Ansehen/Herunterladen” (Read-only)
I do have the very same problem. Only the option “view and download” is visible in the public link creation windows.
I have looked at all the settings (in the share section) without finding wich parameter I have to set to allow editing.
In the setting all the option are on for Default user and group share permissions:
How could I allow editing of shared files ?
Thanks for answering,
Yes it is.
(sorry, it’s in French).
I found a solution. When I share a dossier, I get the full options. So I put the file in a dossier and got the public link for the dossier, with the edit option. I did check the link (on a private windows of the browser) and I got access to the edition of the file in OnlyOffice.
What is funny, is that if I create a public link for the file inside the dossier I got only the option for view and download…
