Source code review by Synk throws up 300+ CVEs
Hi ownCloud creators,
I am keen to use ownCloud for my company project. However, a quick scan using Synk shows > 300+ possible vulnerabilities.
Would anyone be able to advise if there’s some patches we can apply to bring down the vulnerabilities to a more manageable level say < 100?
Thank you.
Screenshot from Synk scanner:
