Server branch: 9.0.1
On the log I have fatal error due to a directory with character " ’ " inside.
Is it normal?
If yes, is there a possibility to add special character in a list to be accepted?
The " ’ " seems not to be allowed in directory name, is anybody can confirmed me that?
And for file name " ’ " is allowed?
Thank you for your answer.
J DEV
Creating a directory named ’ works for me with ownCloud 10. Please consider upgrading.
Tested with 9.1.6 as well. Works just fine.
Thank you for your reply, I test on another server, It’s working for me also, the problem comes not from that. I will try to understand the logs… and open another post with the correct problem if I find out.
