- no idea
When I klick on a directory in the files view I expect to get into the directory and see the files there.
When I klick on a directory the directory icon gets checked. When I klick again it gets unchecked. I cannot access any directory. Not even with double klick.
I rebooted the server but the behaviour stays.
Debian
apache
10.4.1
10.4.0 using the internal updater
bitnami vmware current version
no
no
no
firefox,chrome
win10
