- Moved data folder to an external HDD
- modifications to the path in the config.php were done
- When uploading or creating a folder on owncloud, it recreates the data folder inside the previous default location
- Gives me the message (in owncloud.log which is in the right new location): User backend OC User Database is returning home … user which differs from existing value
Have the data in the new location
The owncloud.log file is in the correct new location but nothing else is here. What can I do? I haven’t seen on the forum or anywhere how to solve this problem…
Content of owncloud.log:
“reqId”:“Jvj0dpLwJjsMYP4pWyXI”,“level”:3,“time”:“2019-12-22T09:17:48+00:00”,“remoteAddr”:“192.168.1.154”,“user”:"–",“app”:“no app in context”,“method”:“POST”,“url”:"/index.php/login?redirect_url=%252Findex.php%252Fapps%252Ffiles%252F%253Fdir%253D%252F%2526fileid%253D3",“message”:“User backend OC\User\Database is returning home: /mnt/ExternalWD/owncloud/data/jauf for user: jauf which differs from existing value: /var/www/html/owncloud/data/jauf”}
The folder data is recreated in the old location.
Operating system: Ubuntu server 18.04.3 LTS
Web server: Apache
Database: MariaDB
ownCloud version: (see ownCloud admin page) 10.3.2.2
“system”: {
“instanceid”: “ocp3e1uubcv8”,
“trusted_domains”: [
“192.168.1.105”
“datadirectory”: “/mnt/ExternalWD/owncloud/data”,
“overwrite.cli.url”: “http://192.168.1.105/owncloud”,
“dbtype”: “mysql”,
“version”: “10.3.2.2”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“loglevel”: 2,
“maintenance”: false,
“theme”: “”,
“updater.secret”: “REMOVED SENSITIVE VALUE”
“apps”: {
“audioplayer”: {
“enabled”: “yes”,
“installed_version”: “2.8.4”,
“signed”: “true”,
“types”: “filesystem”
“backgroundjob”: {
“lastjob”: “128”
“comments”: {
“enabled”: “yes”,
“installed_version”: “0.3.0”,
“types”: “logging,dav”
“configreport”: {
“enabled”: “yes”,
“installed_version”: “0.2.0”,
“core”: {
“backgroundjobs_mode”: “cron”,
“enable_external_storage”: “no”,
“first_install_version”: “10.0.10.4”,
“installedat”: “1538424966.4386”,
“lastcron”: “1570891449”,
“lastupdateResult”: “[]”,
“lastupdatedat”: “1577006268”,
“oc.integritycheck.checker”: “[]”,
“public_files”: “files_sharing/public.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”,
“updater.secret.created”: “1573414247”,
“vendor”: “owncloud”
“dav”: {
“enabled”: “yes”,
“installed_version”: “0.5.0”,
“federatedfilesharing”: {
“enabled”: “yes”,
“federation”: {
“enabled”: “yes”,
“installed_version”: “0.1.0”,
“types”: “authentication”
“fictitious”: {
“datadir”: “/mnt/ExternalWD/owncloud/”
“files”: {
“cronjob_scan_files”: “500”,
“enabled”: “yes”,
“installed_version”: “1.5.2”,
“files_external”: {
“enabled”: “yes”,
“installed_version”: “0.7.1”,
“ocsid”: “166048”,
“files_mediaviewer”: {
“enabled”: “yes”,
“installed_version”: “1.0.1”,
“types”: “”
“files_pdfviewer”: {
“enabled”: “no”,
“installed_version”: “0.11.1”,
“ocsid”: “166049”,
“signed”: “true”,
“types”: “”
“files_sharing”: {
“enabled”: “yes”,
“installed_version”: “0.12.0”,
“files_trashbin”: {
“enabled”: “yes”,
“installed_version”: “0.9.1”,
“files_versions”: {
“enabled”: “yes”,
“installed_version”: “1.3.0”,
“files_videoplayer”: {
“enabled”: “yes”,
“installed_version”: “0.10.1”,
“types”: “”
“firstrunwizard”: {
“enabled”: “yes”,
“installed_version”: “1.2.0”,
“ocsid”: “166055”,
“types”: “”
“gallery”: {
“enabled”: “yes”,
“installed_version”: “16.1.1”,
“signed”: “true”,
“types”: “”
“impersonate”: {
“enabled”: “yes”,
“signed”: “true”,
“types”: “”
“market”: {
“audioplayer”: “2.8.4”,
“enabled”: “yes”,
“files_pdfviewer”: “0.11.0”,
“gallery”: “16.1.1”,
“impersonate”: “0.5.0”,
“key”: null,
“market”: “0.4.0”,
“richdocuments”: “2.1.2”,
“signed”: “true”,
“types”: “”
“notifications”: {
“enabled”: “yes”,
“types”: “logging”
“provisioning_api”: {
“enabled”: “yes”,
“types”: “prevent_group_restriction”
“richdocuments”: {
“enabled”: “yes”,
“installed_version”: “2.2.0”,
“ocsid”: “174727”,
“signed”: “true”,
“systemtags”: {
“enabled”: “yes”,
“types”: “logging”
“updatenotification”: {
“core”: “10.2.1”,
“enabled”: “yes”,
“installed_version”: “0.2.1”,
“notify_groups”: “[]”,
“types”: “”
“wallpaper”: {
“enabled”: “no”,
“installed_version”: “0.1”,
“signed”: “true”,
“types”: “”
