good evening, I encounter a strange problem when loading photos in any folder in the cloud … start loading but in the end I see a file called: “NotFoundError”, this file is a .dms, I only encounter this problem by uploading photos that I took Saturday, any other file I try to upload (photos, videos, pdf, word) are loaded normally, these photos (in any position try to upload them) I get this error … do you have any idea what it might be?
the problem I detect it by uploading any file
Could you share with us related data/owncloud.log lines to better help you? Thanks
“,“app”:“PHP”,“method”:“GET”,“url”:”/owncloud/index.php/login",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“7lbS1DI4isqdQAT8JkiV”,“level”:3,“time”:“2018-06-19T11:55:54+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“7lbS1DI4isqdQAT8JkiV”,“level”:3,“time”:“2018-06-19T11:55:54+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“CssUk4Rg5EnWIyrLICCm”,“level”:3,“time”:“2018-06-19T11:55:54+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“CssUk4Rg5EnWIyrLICCm”,“level”:3,“time”:“2018-06-19T11:55:54+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“u7u6HcdOeh6EOXwdDvpx”,“level”:3,“time”:“2018-06-19T11:56:22+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“u7u6HcdOeh6EOXwdDvpx”,“level”:3,“time”:“2018-06-19T11:56:22+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“PgCQ4WpiIaKAhDehPlY2”,“level”:3,“time”:“2018-06-19T11:56:22+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/login",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“PgCQ4WpiIaKAhDehPlY2”,“level”:3,“time”:“2018-06-19T11:56:22+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/login",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“WEnxvlunSxpMFWYoOWiu”,“level”:3,“time”:“2018-06-19T11:56:22+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“WEnxvlunSxpMFWYoOWiu”,“level”:3,“time”:“2018-06-19T11:56:22+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“idABiYMZaIYUud3zpSXk”,“level”:3,“time”:“2018-06-19T11:57:25+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/login",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“idABiYMZaIYUud3zpSXk”,“level”:3,“time”:“2018-06-19T11:57:25+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/login",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“sLvJylB6inio95V4pRlB”,“level”:3,“time”:“2018-06-19T11:57:25+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“sLvJylB6inio95V4pRlB”,“level”:3,“time”:“2018-06-19T11:57:25+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“9JJdgP35XpwK7ru9MnWf”,“level”:3,“time”:“2018-06-19T11:57:25+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/legacy/util.php#974”}
{“reqId”:“9JJdgP35XpwK7ru9MnWf”,“level”:3,“time”:“2018-06-19T11:57:25+00:00”,“remoteAddr”:“192.168.1.127”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=fdf443c24491c8d84bc84319ff30e999",“message”:“chmod(): Operation not permitted at /var/www/owncloud/lib/private/Log/Owncloud.php#132”}
{“reqId”:“7iAGC6wtG4OXjqmtMjtr”,“level”:2,“time”:“2018-06-19T11:59:31+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/CRI/Foto%20Attivit%C3%A0/Percorso%20Giovent%C3%B9/NotFoundError",“message”:“Could not get node for path: “CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError” : File with name CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError could not be located”}
{“reqId”:“f9ZoMpWnZvju74Bv4S1L”,“level”:2,“time”:“2018-06-19T15:40:16+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/CRI/Foto%20Attivit%C3%A0/Percorso%20Giovent%C3%B9/NotFoundError",“message”:“Could not get node for path: “CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError” : File with name CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError could not be located”}
{“reqId”:“IZXCe7a2I95r5XpCXD58”,“level”:2,“time”:“2018-06-19T15:43:39+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/NotFoundError",“message”:“Could not get node for path: “NotFoundError” : File with name NotFoundError could not be located”}
{“reqId”:“Pi8aNtJJLeNbEc7jf02f”,“level”:2,“time”:“2018-06-19T15:44:38+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/CRI/Foto%20Attivit%C3%A0/Percorso%20Giovent%C3%B9/NotFoundError",“message”:“Could not get node for path: “CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError” : File with name CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError could not be located”}
{“reqId”:“5XWcKAPMJiqNoD3vIj7A”,“level”:2,“time”:“2018-06-19T15:52:04+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/CRI/Foto%20Attivit%C3%A0/Percorso%20Giovent%C3%B9/NotFoundError",“message”:“Could not get node for path: “CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError” : File with name CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError could not be located”}
{“reqId”:“4hPn7To7yR7RvqThmVfX”,“level”:2,“time”:“2018-06-19T18:39:48+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/CRI/Foto%20Attivit%C3%A0/Percorso%20Giovent%C3%B9/NotFoundError%20(2)",“message”:“Could not get node for path: “CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError (2)” : File with name CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError (2) could not be located”}
{“reqId”:“FyYNVb2wn9Z77xvQhTg9”,“level”:2,“time”:“2018-06-19T18:39:48+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/CRI/Foto%20Attivit%C3%A0/Percorso%20Giovent%C3%B9/NotFoundError",“message”:“Could not get node for path: “CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError” : File with name CRI/Foto Attivit\u00e0/Percorso Giovent\u00f9/NotFoundError could not be located”}
{“reqId”:“vwM9r1XGEPFYmebMw90k”,“level”:2,“time”:“2018-06-19T18:40:35+00:00”,“remoteAddr”:“192.168.1.127”,“user”:“nemo”,“app”:“dav”,“method”:“DELETE”,“url”:"/owncloud/remote.php/webdav/NotFoundError",“message”:“Could not get node for path: “NotFoundError” : File with name NotFoundError could not be located”}Preformatted text
Looks to me that you have some permission issues on your installation / the ownCloud install folder.
giving the command:
sudo chown www-data:www-data /mnt/data
chown -R www-data:www-data /mnt
the data folder is present on an external hd connected to the raspberry, I continue to find the same error
Could it be possible that the external HD is not partitioned with a linux filesystem? If it is using e.g. NTFS that would be not supported by ownCloud from what i have read in the past.
no, the hd is formatted in ext4
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 96453 88262 43,1M c W95 FAT32 (LBA)
/dev/mmcblk0p2 98304 30318591 30220288 14,4G 83 Linux
Disk /dev/sda: 1,8 TiB, 2000398931968 bytes, 3907029164 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x63b9046e
/dev/sda1 2048 3907028991 3907026944 1,8T 83 Linux
Now I see this message: “errors occurred with the integrity check of the code”, if I open: “invalid file list” I see this:
Technical information
them.
Results
- core
- INVALID_HASH
- .htaccess
- INVALID_HASH
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[.htaccess] => Array
[expected] => c00197d1a4d7a1db5bf43849acd10d2d7813705463ba02fe540b5d05328dcf078456e55dcd0450bb884a85bf25c66a596cdcf9108d26ba44d2287a35de26d72b
[current] => 9ae26b7e82553d870f1ff779bb675d25f82cfb742445acc05b0c6bf71fbe78e63a1f2361243e8834b77b157e4d130ce77a325c58abae5ca838d189e35de0fb70
