So how do you actually enable this?
I suppose it should be done in .htaccess, right?
But the documentation doesn’t tell much on how you ACTUALY do it:
Anyone here that kindly would enlighten me on how you do apply it correctly, please?
Thanks in advance!
alfredb
#2
I’ve added it in the file /etc/apache2/sites-enabled/000-default.conf.
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000"
</IfModule>
That should be the preferred way whenever possible, as it avoids issues on ownCloud updates and with the integrity check.
Thank you for the help!
Kind regards
system
Closed
#5
