I can find repo’s that will download owncloud 10 file for me… but they won’t work as an upgrade from 9.0.4.1, they just tell me that I need to upgrade from 9.0.8. But I can’t find a way to get to 9.0.8. I’ve linked several repo’s, cleared apt cache and updated but nothing will update my packages to 9.0.8. The install goes back to 6.0.
Operating system: Wheezy
Web server: Apache2.2.22-13
Database: MySQL 5.5
PHP version: 5.4.45
ownCloud version: ownCloud 9.0.4 (stable)
Updated from an older ownCloud or fresh install: Updated from older
Where did you install ownCloud from: Repo’s long ago
Signing status (ownCloud 9.0 and above): N/A
The content of config/config.php: No thank you!
- activity: 2.2.1
- comments: 0.2
- contacts: 1.3.1.0
- dav: 0.1.6
- documents: 0.12.0
- federatedfilesharing: 0.1.0
- files: 1.4.4
- files_external: 0.5.2
- files_pdfviewer: 0.8.1
- files_sharing: 0.9.1
- files_texteditor: 2.1
- files_trashbin: 0.8.0
- files_versions: 1.2.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 14.5.0
- notifications: 0.2.3
- provisioning_api: 0.4.1
- systemtags: 0.2
- templateeditor: 0.1
- updatenotification: 0.1.0
Disabled:
- encryption
- external
- federation
- files_antivirus
- user_external
- user_ldap
[Symfony\Component\Console\Exception\CommandNotFoundException]
There are no commands defined in the "ldap" namespace.
Empty set (0.00 sec)
