when i try to open a word file in my owncloud folder, it comes
"Collabora Online: Cannot connect to the host "https://localhost:9980". Please ask your administrator to check the Collabora Online server setting. The exact error message was: cURL error 7: Failed to connect to localhost port 9980: Connection refused"
thanks a lot if anyone can help me work it out
Do you use the appliance?
it’s passed one year and i have the same problem…any solution?
Can you provide more info to your problem?
i have the same problem…on github i contact the developer of app.
seem missing code collabora installing…but it’s very hard found update tutorial to install without docker
Okay, that does not provide anything new.
Can you provide specific information about your problem so people can try to fix it?
i haven’t docker i follow this istruction https://www.collaboraoffice.com/code/
but when i launch the last line i have this error
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:6 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:6 W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:7 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:7 W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:8 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:8 E: The method driver /usr/lib/apt/methods/https could not be found. N: Is the package apt-transport-https installed? E: The method driver /usr/lib/apt/methods/https could not be found. N: Is the package apt-transport-https installed? E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu1804/./InRelease E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE/./InRelease E: Some index files failed to download. They have been ignored, or old ones used instead. W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:6 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:6 W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:7 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:7 W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:8 W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:8
can you clean your sources.list? There are many error messages
Collabora Online: Cannot connect to the host “https://localhost:9980”.
when going to collabora after install
“:“Undefined index: filename at /var/www/html/owncloud/apps/richdocuments/controller/documentcontroller.php#390”}
{“reqId”:“0EjXeXfBNBy0zdr2wYgJ”,“level”:3,“time”:“2018-09-21T20:42:36-04:00”,“remoteAddr”:“192.168.1.9”,“user”:“xxxxx”,“app”:“PHP”,“method”:“POST”,“url”:”/index.php/apps/richdocuments/ajax/documents/create",“message”:“Undefined index: dir at /var/www/html/owncloud/apps/richdocuments/controller/documentcontroller.php#391”}
can you try to configure a dns name for your ownCloud installation, and point collabora to that?
I don’t know if it works with localhost, like in your installation.
are you refering to db_host or redis
‘redis’ =>
array (
‘host’ => ‘localhost’,
No I mean DNS.
You are accessing your instance right now with localhost something.
What you can do is map your IP to a domain name in your /etc/hosts file.
Like: 192.168.3.1 mysupermegagoodserver.com
So if you type in your browser mysupermegagoodserver.com you get redirected to 192.168.3.1
Isn’t /etc/resolv.conf who handles that.
Anyhow i will try pointing my host to my dns
