Trashbin_retention_obligation doesn't work
Hi
I got an issue with the auto delet of the trash. I changed my config.php to the following:
'trashbin_retention_obligation' => '30, 31',
But it doesn't delete anything. I tested cron AJAX and webcron but neither of them worked at all the files are still in the trash.
Got someone an idea what I could try to fix this?
regards
so you have waited for 32 days and the files are still there?
No I change it today but my trash contains files that are older than two months.
Is that a problem?
Maybe its also just a bug. Some environments are sometimes missing the cron entry in the database for unknown reasons:
okay Is there a way to fix it?
Maybe you read something out from the bugreport above. If its not working as expected you could also create a bugreport at:
https://github.com/owncloud/core/issues
and maybe a fix is provided there.
