Install fresh using http://www.avoiderrors.net/owncloud-raspberry-pi/ I changed the part about the owncloud to the one listed on the owncloud website.
Test on the local network, change the data location using this guide https://www.digitalocean.com/community/tutorials/how-to-move-the-data-directory-for-owncloud-on-ubuntu-16-04
- Port forward,
I got the server installed. Started with the administrator account. Made one for me as a user. Poked around. Downloaded the desktop app. Logged in with that.
The thing is I can log into the server on that local network, but not externally. I can SSH in all day and I know I set up port forwarding on 80 and 443.
Going to my url or using the external IP address I get a redirect to
Raspbian jesse light from the pi site
Nginx
I don't think I set this up
10
Fresh
Owncloud's site
"system": {
"instanceid": "oc8o2ma8kur0",
"trusted_domains": [
"192.168.10.112"
"overwrite.cli.url": "https:\/\/192.168.10.112",
"dbtype": "sqlite3",
"version": "10.0.2.1",
"logtimezone": "UTC",
"installed": true
Are you using external storage, if yes which one: local/smb/sftp/...
No
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
No
[Symfony\Component\Console\Exception\CommandNotFoundException]
There are no commands defined in the "ldap" namespace.
#### Browser log
c) ...`
