I haven't remove port 443 for Owncloud IP Address, but for other IP Addresses where port 443 has been set are removed. 1) For Windows Server IP Address in the router - > port 443 disabled 2) For Owncloud IP Address in the router - > port 443 enabled
You should draw an x-ray view of ingress traffic entering into the router, means the traffic coming from outside into the router.
@dmitry Hi dmitry, Sorry to bother you again, you say reinstall the appliance, which appliance, the own cloud server or the others like "Active Directory-compatible Domain Controller"??
If is own cloud server , i don't see "integrate the appliance in my active directory". If is "Active Directory-compatible Domain Controller",why i can't install, when i click that appliance, on the bottom of the web site show "Network is unreachable"
"You can setup the appliance as before, and edit the hosts file." , i also don't know that means? could you describe it detailly..
Please open up a new issue with description of your setup, the steps you took to install the appliance, what are you trying to achieve and what went wrong.
