domi77
November 14, 2016, 9:06am
1
Hello Forum,
I tried to upgrade my owncloud 8.0.3. to version 8.2.9. on a testing environment (local webserver with macports) where everything worked fine. The Updater started and made all the necessary changes. When I do the same procedure on the production server (Ubuntu 14.04 LTS), I always get an Server Error 500. When I look into the owncloud.log, it seems that there are missing classes. I don´t understand that behaviour, because in that testing enviroment I used an exact copy of the production system. Did anyone have similar problems or can help me to get the update working? Thanks
regards, Dominik
How did you update?
Did you directly update from 8.0.x to 8.2.x?
domi77
November 14, 2016, 10:17am
3
Hello Victor,
yes I did. I removed everything except config/ and data/ and moved the new files at the same place.
Regards
direct updates are not supported, you have to upgrade every single major-version in between.
so the correct steps are:8.0.x -> 8.1.x -> 8.2.x
what version do you have in your config.php?
domi77
November 14, 2016, 1:12pm
5
My fault, the currect Version is 8.1.3.0. So I didn´t update two major versions, but the question why it works in testing enviroment remains. Thx
Regards
could you please provide us the exact steps you've been using to upgrade your instance, step by step?
and, if possible, provide us your current apache-config (etc/apache2/sites-enabled/owncloud.conf).
as you said, you have an EXACT copy of your environment, i hope you didnt forget to change DNS and IP-addresses
domi77
November 14, 2016, 2:04pm
7
Here´s my Apache Config:
000-default.conf:
<VirtualHost *:80>
ServerName xxx.x.xx.xxx:80
ServerAdmin admin@domain.tld
DocumentRoot /var/www/owncloud
Alias /owncloud /var/www/owncloud
<Directory /var/www/owncloud/>
Options FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
Allow from all
Satisfy Any
</Directory>
</VirtualHost>
default-ssl.conf:
NameVirtualHost *:443
<VirtualHost *:443>
ServerName xxx.x.xx.xxx:443
SSLEngine On
SSLCertificateFile /etc/ssl/certs/ssl-cert-xxx.crt
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-xxx.key
</VirtualHost>
My Update steps were no magic, I removed everything in "var/www/owncloud/" except "config/config.php" & "data/". After that I pasted the new files from the 8.2.9 archive and called the webinterface (the "config/" has not been overwritten with an empty one). The owncloud install recognized that it needs a update (apps, db, and so on), so I pressed "Start the updater" or whatever the button was called. After that everything was fine, in the test enviroment. I repeated those steps on the server - with a result of Error 500.
Regards
P.S.: I just changed the DNS and IP settings on my test enviroment after I copied the files, on the server everything stayed the same. I also didn´t copy anything back from the test enviroment, so everything should be fine with my DNS and IP settings.
did you do:
chown -R www-data:www-data /path/to/owncloud
domi77
November 14, 2016, 2:13pm
9
Yes, I had to change the owner, before removing the files and pasting the new. After that I used this script, to set the ownership and right back:
#!/bin/bash
ocpath='/var/www/owncloud'
htuser='www-data'
htgroup='www-data'
find ${ocpath}/ -type f -print0 | xargs -0 chmod 0640
find ${ocpath}/ -type d -print0 | xargs -0 chmod 0750
chown -R root:${htuser} ${ocpath}/
chown -R ${htuser}:${htgroup} ${ocpath}/apps/
chown -R ${htuser}:${htgroup} ${ocpath}/config/
chown -R ${htuser}:${htgroup} ${ocpath}/data/
chown -R ${htuser}:${htgroup} ${ocpath}/themes/
chown root:${htuser} ${ocpath}/.htaccess
chown root:${htuser} ${ocpath}/data/.htaccess
chmod 0644 ${ocpath}/.htaccess
chmod 0644 ${ocpath}/data/.htaccess
thats odd, I dont see what you did wrong in the first place.
how about removing the default-configs and replace them with a new one?
as an example:
unlink /etc/apache2/sites-enabled/000-default.conf
nano /etc/apache2/sites-enabled/owncloud.conf
<VirtualHost *:80>
#### Redirect to port 443 ###
RewriteEngine on
ReWriteCond %{SERVER_PORT} !^443$
RewriteRule ^/(.*) https://%{HTTP_HOST}/$1 [NC,R,L]
#### End of Redirection configuration ###
ServerName yourdomain.ch
ServerAdmin admin@yourdomain.ch
<Directory /var/www/owncloud>
Options +FollowSymlinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/owncloud
SetEnv HTTP_HOME /var/www/owncloud
</Directory>
</VirtualHost>
<VirtualHost *:443>
####Configuration for SSL #####
SSLEngine on
SSLCertificateFile /etc/apache2/ssl/.yourcert.crt
SSLCertificateKeyFile /etc/apache2/ssl/.yourkey.key
SSLCertificateChainFile /etc/apache2/ssl/rapidssl_intermediate.crt
#### End of SSL Configuration ####
Header always add Strict-Transport-Security "max-age=15768000"
DocumentRoot /var/www/owncloud/
<Directory /var/www/html/owncloud>
AllowOverride All
Dav off
</IfModule>
</Directory>
</VirtualHost>
maybe this helps?
domi77
November 14, 2016, 2:23pm
11
Thanks for your help. I´ll try this later today.
Regards, Dominik
