Hello @DeepDiver 1975
Some parts are translated to English !
The ownCloud log shows :
text/plain owncloud.log ( ASCII text, with very long lines )
{“reqId”:“aujvP6LUXBBsac9BVi0-JwAAAEQ”,“level”:3,“time”:“2026-11-02T21:14:55+01:00”,“remoteAddr”:“212.88.13.76”,“user”:“–”,“app”:“index”,“method”:“GET”,“url”:“/cloud/index.php/core/js/oc.js?v=1b1225d27719695a13af26586c2f7ee6”,“message”:“Exception: {“Exception”:“OC\\NeedsUpdateException”,“Message”:”“,“Code”:0,“Trace”:”#0 \/home\/XXXXXX\/public_html\/cloud\/lib\/private\/legacy\/app.php(221): OC_App::loadApp(‘federation’)\n#1 \/home\/XXXXXX\/public_html\/cloud\/lib\/kernel.php(885): OC_App::loadApps(Array)\n#2 \/home\/XXXXXX\/public_html\/cloud\/index.php(33): OC::handleRequest()\n#3 {main}“,“File”:”\/home\/XXXXXX\/public_html\/cloud\/lib\/private\/legacy\/app.php",“Line”:285}"}
Content-Security-Policy: The page settings have blocked the execution of an inline script (script-src-elem) because it violates the following directive: “script-src ‘self’ ‘unsafe-eval’”. Consider using a Hashs (‘sha256-Y1z0SyVx5S7ywM8HEuxVVkmBpqUjj6qZLBNBVk8E6h8=’) or consider a nonce. inject.js:31:26
GET
https://XXXXXX.xx/cloud/index.php/core/js/oc.js?v=1b1225d27719695a13af26586c2f7ee6
NS_ERROR_CORRUPTED_CONTENT
Layout display was forced before the page was fully loaded. If stylesheets are not yet loaded, this may result in the content being displayed for a short time without formatting. rc2Contentscript.js:247:11
TypeError: can’t access property “scrollHeight”, document.body is null rc2Contentscript.js:249:77
Die Ressource von “https://XXXXXX.xx/cloud/index.php/core/js/oc.js?v=1b1225d27719695a13af26586c2f7ee6” was due to a MIME type conflict (“text/html”) blocked(X-Content-Type-Options: nosniff). index.php
Loading failed for the item with the source “https://XXXXXX.xx/cloud/index.php/core/js/oc.js?v=1b1225d27719695a13af26586c2f7ee6”. index.php:32:90
In the Network tab there is no Set-Cookie header, only GET’s
In the config.php there are no overwrite commands
Unfortionatly I have no access to session.save_path setting.
I have tried your suggestion with ‘csrf.disabled’ => true and got following warnings:
Warning: file_put_contents(/home/XXXXXX/public_html/cloud/data/crash-2026-11-02.log): Failed to open stream: No such file or directory in /home/XXXXXX/public_html/cloud/lib/kernel.php on line 1041
I really hope this helps.
