Hello!
I run owncloud 10.0.2 on a ubuntu server 16.04.3 LTS without problems.
I updatet owncloud with this guid to 10.0.3.
Ubuntu_16.04 owncloud-files-10.0.3-1.1
You can add the repository key to apt. Keep in mind that the owner of the key may distribute updates, packages and repositories that your system will trust (more information). Run the following shell commands as root to trust the repository:
wget -nv https://download.owncloud.org/download/repositories/production/Ubuntu_16.04/Release.key -O Release.key
apt-key add - < Release.key
Run the following shell commands as root to add the repository and install from there.
echo 'deb http://download.owncloud.org/download/repositories/production/Ubuntu_16.04/ /' > /etc/apt/sources.list.d/owncloud.list
apt-get update
apt-get install owncloud-files
After this, when i connect via Browser to my cloud,
i get errors about the integrity check.
Technical information
them.Results
- core
- EXTRA_FILE
- core/doc/user/files/file_drop.html
- core/doc/user/files/access_webgui.html
- core/doc/user/files/quota.html
- core/doc/user/webdav-api/index.html
- core/doc/user/_images/files-drop-4.png
- core/doc/user/_images/files-drop-7.png
- core/doc/user/_images/files-drop-3.png
- core/doc/user/_images/files-drop-2.png
- core/doc/user/_images/files-drop-6.png
- core/doc/user/_images/files-drop-5.png
- core/doc/user/_sources/files/file_drop.txt
- core/doc/user/_sources/files/quota.txt
- core/doc/user/_sources/files/access_webgui.txt
- core/doc/user/_sources/webdav-api/index.txt
- core/doc/admin/configuration_mimetypes/index.html
- core/doc/admin/configuration_mimetypes/mimetype_aliases.html
- core/doc/admin/configuration_mimetypes/mimetype_mapping.html
- core/doc/admin/installation/appliance_installation.html
- core/doc/admin/installation/nginx_examples.html
- core/doc/admin/configuration_user/index.html
- core/doc/admin/configuration_user/user_auth_ldap.html
- core/doc/admin/configuration_user/reset_user_password.html
- core/doc/admin/configuration_user/user_auth_ftp_smb_imap.html
- core/doc/admin/configuration_user/user_configuration.html
- core/doc/admin/configuration_user/user_provisioning_api.html
- core/doc/admin/configuration_user/reset_admin_password.html
- core/doc/admin/configuration_ldap/ldap_proxy_cache_server_setup.html
- core/doc/admin/configuration_files/index.html
- core/doc/admin/configuration_files/federated_cloud_sharing_configuration.html
- core/doc/admin/configuration_files/external_storage_configuration.html
- core/doc/admin/configuration_files/trashbin_options.html
- core/doc/admin/configuration_files/big_file_upload_configuration.html
- core/doc/admin/configuration_files/external_storage_configuration_gui.html
- core/doc/admin/configuration_files/file_versioning.html
- core/doc/admin/configuration_files/encryption_configuration.html
- core/doc/admin/configuration_files/external_storage/webdav.html
- core/doc/admin/configuration_files/external_storage/local.html
- core/doc/admin/configuration_files/external_storage/amazons3.html
- core/doc/admin/configuration_files/external_storage/sftp.html
- core/doc/admin/configuration_files/external_storage/smb.html
- core/doc/admin/configuration_files/external_storage/ftp.html
- core/doc/admin/configuration_files/external_storage/openstack.html
- core/doc/admin/configuration_files/external_storage/google.html
- core/doc/admin/configuration_files/external_storage/owncloud.html
- core/doc/admin/configuration_files/external_storage/dropbox.html
- core/doc/admin/configuration_files/external_storage/auth_mechanisms.html
- core/doc/admin/configuration_files/file_sharing_configuration.html
- core/doc/admin/configuration_files/default_files_configuration.html
- core/doc/admin/configuration_files/previews_configuration.html
- core/doc/admin/configuration_files/files_locking_transactional.html
- core/doc/admin/enterprise/file_management/files_drop.html
- core/doc/admin/configuration_database/index.html
- core/doc/admin/configuration_database/db_conversion.html
- core/doc/admin/configuration_database/linux_database_configuration.html
- core/doc/admin/_images/sharing-files-1.png
- core/doc/admin/_images/community-vm-splash.png
- core/doc/admin/_images/install-wizard-a2.png
- core/doc/admin/_images/files-drop-1.png
- core/doc/admin/_images/community-vm-console.png
- core/doc/admin/_sources/configuration_mimetypes/index.txt
- core/doc/admin/_sources/configuration_mimetypes/mimetype_mapping.txt
- core/doc/admin/_sources/configuration_mimetypes/mimetype_aliases.txt
- core/doc/admin/_sources/installation/appliance_installation.txt
- core/doc/admin/_sources/installation/nginx_examples.txt
- core/doc/admin/_sources/configuration_user/reset_admin_password.txt
- core/doc/admin/_sources/configuration_user/user_auth_ftp_smb_imap.txt
- core/doc/admin/_sources/configuration_user/index.txt
- core/doc/admin/_sources/configuration_user/user_configuration.txt
- core/doc/admin/_sources/configuration_user/user_auth_ldap.txt
- core/doc/admin/_sources/configuration_ldap/ldap_proxy_cache_server_setup.txt
- core/doc/admin/_sources/configuration_files/file_sharing_configuration.txt
- core/doc/admin/_sources/configuration_files/files_locking_transactional.txt
- core/doc/admin/_sources/configuration_files/encryption_configuration.txt
- core/doc/admin/_sources/configuration_files/previews_configuration.txt
- core/doc/admin/_sources/configuration_files/federated_cloud_sharing_configuration.txt
- core/doc/admin/_sources/configuration_files/trashbin_options.txt
- core/doc/admin/_sources/configuration_files/external_storage/local.txt
- core/doc/admin/_sources/configuration_files/external_storage/ftp.txt
- core/doc/admin/_sources/configuration_files/external_storage/auth_mechanisms.txt
- core/doc/admin/_sources/configuration_files/big_file_upload_configuration.txt
- core/doc/admin/_sources/configuration_files/external_storage_configuration_gui.txt
- core/doc/admin/_sources/configuration_files/file_versioning.txt
- core/doc/admin/_sources/configuration_files/default_files_configuration.txt
- core/doc/admin/_sources/enterprise/file_management/files_drop.txt
- core/doc/admin/_sources/configuration_database/linux_database_configuration.txt
- core/doc/admin/_sources/configuration_server/background_jobs_configuration.txt
- core/doc/admin/_sources/configuration_server/harden_server.txt
- core/doc/admin/_sources/configuration_server/antivirus_configuration.txt
- core/doc/admin/_sources/configuration_server/automatic_configuration.txt
- core/doc/admin/_sources/configuration_server/caching_configuration.txt
- core/doc/admin/_sources/configuration_server/index.txt
- core/doc/admin/_sources/configuration_server/external_sites.txt
- core/doc/admin/_sources/configuration_server/security_setup_warnings.txt
- core/doc/admin/_sources/configuration_server/email_configuration.txt
- core/doc/admin/_sources/configuration_server/oc_server_tuning.txt
- core/doc/admin/_sources/configuration_server/config_sample_php_parameters.txt
- core/doc/admin/_sources/configuration_server/occ_command.txt
- core/doc/admin/_sources/configuration_server/index_php_less_urls.txt
- core/doc/admin/configuration_server/activity_configuration.html
- core/doc/admin/configuration_server/config_sample_php_parameters.html
- core/doc/admin/configuration_server/oc_server_tuning.html
- core/doc/admin/configuration_server/index.html
- core/doc/admin/configuration_server/import_ssl_cert.html
- core/doc/admin/configuration_server/antivirus_configuration.html
- core/doc/admin/configuration_server/automatic_configuration.html
- core/doc/admin/configuration_server/background_jobs_configuration.html
- core/doc/admin/configuration_server/thirdparty_php_configuration.html
- core/doc/admin/configuration_server/custom_client_repos.html
- core/doc/admin/configuration_server/caching_configuration.html
- core/doc/admin/configuration_server/harden_server.html
- core/doc/admin/configuration_server/language_configuration.html
- core/doc/admin/configuration_server/logging_configuration.html
- core/doc/admin/configuration_server/external_sites.html
- core/doc/admin/configuration_server/security_setup_warnings.html
- core/doc/admin/configuration_server/knowledgebase_configuration.html
- core/doc/admin/configuration_server/email_configuration.html
- core/doc/admin/configuration_server/occ_command.html
- core/doc/admin/configuration_server/index_php_less_urls.html
- core/doc/admin/configuration_server/excluded_blacklisted_files.html
- core/doc/admin/configuration_server/js_css_asset_management_configuration.html
- core/doc/admin/configuration_server/reverse_proxy_configuration.html
- updater/src/Command/DisableNotShippedAppsCommand.php
- updater/src/Command/EnableNotShippedAppsCommand.php
- settings/Controller/SecuritySettingsController.php
- configreport
- EXTRA_FILE
- lib/ConfigReportEvent.php
- files_sharing
- EXTRA_FILE
- appinfo/database.xml
- lib/External/Scanner.php
- files
- EXTRA_FILE
- templates/admin.php
- lib/Panels/Admin.php
- js/admin.js
- ajax/setupload.php
- dav
- EXTRA_FILE
- lib/Migration/FixBirthdayCalendarComponent.php
- federatedfilesharing
- EXTRA_FILE
- notifications
- EXTRA_FILE
- files_trashbin
- EXTRA_FILE
- market
- EXTRA_FILE
- css/market.min.css
- files_antivirus
- EXTRA_FILE
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[core/doc/user/files/file_drop.html] => Array
[expected] =>
[current] => 7d75b62addbd4a2ad0c2ac377d01cd96c602b99d8ac42f0ce9984e230caa94eb11496df9880afbb74dd92f13040d2309635653226d79b444d2cef2b087f23d17
)[core/doc/user/files/access_webgui.html] => Array ( [expected] => [current] => b30d712603854011866cf29185e44ecbf09d78e71c059f61e53179bc972f98c4fd401ee7c21dec1682cc3a309fa3825682e26c55035d5eb2178f8d84ba6a7ada ) [core/doc/user/files/quota.html] => Array ( [expected] => [current] => ff0b4c738622e2195ddee0043d635b88d8cd5ae51b6dcaba03edade0169618b8c4f40c4c73557b60558b8e14d4ca25b4fefcdd909699b5ed144eaf35b47db5e9 ) [core/doc/user/webdav-api/index.html] => Array ( [expected] => [current] => 28e48c9ec09c73e95375cc436e440bb12e690e28841a8683d6f2a8ad4f2abb9ba33494a1010f8c9ac30d61fe6bf5278d6411baf7a5bb6d3121e2244460dc9378 ) [core/doc/user/_images/files-drop-4.png] => Array ( [expected] => [current] => 232f81dac973e78fe77969c1e2cfa05903a2414f34df92afcaea866a72fbaa008c7a5958091593320fdd79774c6623220ec76319e9a380c82c29a3618b975e99 ) [core/doc/user/_images/files-drop-7.png] => Array ( [expected] => [current] => 5cd56220c8ee8d93c2bef0ef5eb5b0415db49c5e67930362bcf05871750fcde4913e21815f3a52bbad7ed4dff7229b646a85e94e80fece8f849f3578976fefbd ) [core/doc/user/_images/files-drop-3.png] => Array ( [expected] => [current] => 17cde92a92afa06c9c9b9a120062774a8181f9716b92a481f35e3815a620cb307ffa954f6540118e87b3c8d7b1b3d26a3d9c267f8db49c9f01874527b050357b ) [core/doc/user/_images/files-drop-2.png] => Array ( [expected] => [current] => f87347f514162c470b45ad2cd46db542c9c9b4cf36929daa63c89e19deb328afe039a880d44e201829b66da5468b8e74f20f8cf7bb394c4ff4f9971898d1d4f9 ) [core/doc/user/_images/files-drop-6.png] => Array ( [expected] => [current] => b3a7b750068e801f26cb8f715c14178839634eb54f9cef0788f591e96b6a366945eaebe9f9eaaecfacfbdf1b95af01fd306192323647fb8b24b5802f47e7f094 ) [core/doc/user/_images/files-drop-5.png] => Array ( [expected] => [current] => 2261583e9637a8a7d51af2b5453c1db7ec7425ed7d861856c389c5ca9c502f1ef717d819a79bd69963a424a21879ce05b61df51c2a02976ba7fd58042fdbb761 ) [core/doc/user/_sources/files/file_drop.txt] => Array ( [expected] => [current] => 60e2acbb3662709b7087262c751aedf1c078cf753487608a856cea8d721e6116cadd434e6e11707f8ac87c24812975e3c93f062906a5b20e558b2f1179bb4d9e ) [core/doc/user/_sources/files/quota.txt] => Array ( [expected] => [current] => 0c41e3fa4bb5ecdd04d3d37777f55fa5a04916284fac33e30ec287ed7f01734574f6af5352549457561d8ce50fc1b41a20dc4968ffcfbcf173e680de3be09550 ) [core/doc/user/_sources/files/access_webgui.txt] => Array ( [expected] => [current] => 66925b0a47dd29dc0d61d6515aa22f902b792089fcc5252a5110f2281cc6e86d2e66c51176ad6694f5b5a0868ec6a32172b31afc396dd4fa2acf5a94525e31d9 ) [core/doc/user/_sources/webdav-api/index.txt] => Array ( [expected] => [current] => 73c35efc68fb3bcd27b90045a67decae398430b972f32466a3db7fdf9154ce4e6c072f011df5acb3c62bd186df28549e85d7a1ec4aedb1314358b72adea7ffab ) [core/doc/admin/configuration_mimetypes/index.html] => Array ( [expected] => [current] => dca2e490c8274416a8f03784342e0b6813aa46e0b8fa69f177280952a975d12de9ca0566554e6211db92fad75c71366a87ea0c7950284d50a85a1c85b6176d84 ) [core/doc/admin/configuration_mimetypes/mimetype_aliases.html] => Array ( [expected] => [current] => b6d8c5c293a6a5211cb2a013f8e40fd2351cea8b9ec7317756f64535443db1394d60c98aa9ca006fbb6a3d6283358efa5252349605365ab96f9fbef1b77b5972 ) [core/doc/admin/configuration_mimetypes/mimetype_mapping.html] => Array ( [expected] => [current] => 214055d0ba45053954e657232e7b680eb7eba818e2ff060ea9232b8aa33c800b342494da0cb706b2f4e257ed9059329ab54fe6180d4aa1f87b44882a06bf1eb1 ) [core/doc/admin/installation/appliance_installation.html] => Array ( [expected] => [current] => 68b6ca199dec0bed7b521fb977756085b6b60875acec7b34bd08431abaaea82de813c11b1838d5decb2669f6511cb6d46578b64a97bcb243802c1b5dd9424669 ) [core/doc/admin/installation/nginx_examples.html] => Array ( [expected] => [current] => a6291b78ba8659fe281f0cb84280165385463223a0e6914cf48e0761e2b0932151965c4d2dbb1b0688943c27c5c0622b41f22c01325efd03e10e615561073a0c ) [core/doc/admin/configuration_user/index.html] => Array ( [expected] => [current] => e61188ab262e888651caf9562143ddeb2128d452ce0fca000bd46bf61fa480c8c1f853be64d457d22304eb9a66abe2ef6f42374d31547b6b6dc343646612f282 ) [core/doc/admin/configuration_user/user_auth_ldap.html] => Array ( [expected] => [current] => 0f3fc9b9e341d89aef3adca846c597641cd9b11ee22c3dc343093212a04c35749f719ecfba9a736996bc54ac6e7760f1eb2e7fcf5bd8942bacdd4b97f24edc72 ) [core/doc/admin/configuration_user/reset_user_password.html] => Array ( [expected] => [current] => b51aa8210ed80e978ff2f9bda4b9dfbec4945e10350b1a35f7e5c67347a557337bc4b303d8c0b863e342e62d09d69a8d649e94d207b04590ef20945ecdfb4e9b ) [core/doc/admin/configuration_user/user_auth_ftp_smb_imap.html] => Array ( [expected] => [current] => 8be8cf69501bb37ddb11f0e8d646b9920d3324524d4d5899517190ea66e33dced4270817c6e8a02c5c4209d0a682a1308820fb893369d8cb12cb935eefd0cc1b ) [core/doc/admin/configuration_user/user_configuration.html] => Array ( [expected] => [current] => 7019e08ddb6ab1a749ab60646b41a5a8d3dee9b97681cb465c7f91326addb5d3a08e6309bde769c4d29b5a059c12506efb4ae209206375cb231693f57b6c3ac4 ) [core/doc/admin/configuration_user/user_provisioning_api.html] => Array ( [expected] => [current] => 9215cf806edde8e17732753a5e3d7426a0802b494932fdf803d9b6e7b72d5f5a7ae07d3f3d6d00f9068f48265b9d66c35b78f569e2ccdb48c2572333801b609e ) [core/doc/admin/configuration_user/reset_admin_password.html] => Array ( [expected] => [current] => f6d9c88a04a9e5f410b5a7ec81ae39ab7889607bc5d31f02ae303b80cdebbfa07b5999970fa0f322ea88998cc68557d21c732e0f2ced627e0d247fe94f360381 ) [core/doc/admin/configuration_ldap/ldap_proxy_cache_server_setup.html] => Array ( [expected] => [current] => c1bc2e934c9807ec811fa7897e008a21ef501fea3420158ccb45a73df1648371caa10309e0503ef33599177fbe3ebe1fc78528790f591337abacf138aa451019 ) [core/doc/admin/configuration_files/index.html] => Array ( [expected] => [current] => c21c37aa7dec257b4890242b8ba5de66c3872c0409f0a70b33d31d54b2aa1b67a2f813adaeebf0164eb1b583f14d217deb853a5052c69bf8c8b7639e993c803f ) [core/doc/admin/configuration_files/federated_cloud_sharing_configuration.html] => Array ( [expected] => [current] => 7420d2898e88178a0bbd3de689198d0076c3b036ace79a205e05bbee2be48f1a7ea872dceb8a1faa36901f2ffdcb7c3560e59e6d349a679fbdd846cc384cb10b ) [core/doc/admin/configuration_files/external_storage_configuration.html] => Array ( [expected] => [current] => 74ed09f67ceb49875e5d61a0175ef92b3ed5da5bb128b790b7f2c0c8b6ff542a6caf373969208b66d405751eeacbf80be2ae2dedd065e812b768f386af281f3d ) [core/doc/admin/configuration_files/trashbin_options.html] => Array ( [expected] => [current] => 27b69b31d5a962d5d8860d970c74411ce0ee3f51d373719311ffad243024b0304fedf0b7d5be7c149c740c383faa8d313278c964e9bf31924eaf08ad616483de ) [core/doc/admin/configuration_files/big_file_upload_configuration.html] => Array ( [expected] => [current] => 62dda0bc58170c8995514068569efb33243eafe2106590e49c0fe0c3b4c2b316c8d96f4b6c02a8079a7fea203a417a2d7c4335231419ef5bd700a6838d2ea95f ) [core/doc/admin/configuration_files/external_storage_configuration_gui.html] => Array ( [expected] => [current] => 39b107b8366e9e139c5c980016568d538e94a8c837674e4dc8bc57707823dd57dfa647ce3e829e0b43ab41069c21aa309d548edfc834062f476668e1e215f93b ) [core/doc/admin/configuration_files/file_versioning.html] => Array ( [expected] => [current] => c6e2a93f922afaf68cb9845a909f78b1d8a5aa2e6554d4fa9acc40ee801679a1278cbd79867e35dbad1557a768cb6352cb43a36a765df2402027acae5ba3f14f ) [core/doc/admin/configuration_files/encryption_configuration.html] => Array ( [expected] => [current] => 1ee768099ae3938710850c496e9ca5bb6f651d546138736b16cf93e79a8743b8eb6f737b59cf1a2031b8336474c1ed975c3edea8127a26f0d72e54e9c8ad602f ) [core/doc/admin/configuration_files/external_storage/webdav.html] => Array ( [expected] => [current] => fb307176a927fd61445186bb474282d4d4f82c053f9d1945979f11b4f1c11b8d7fb05d2c2ef53982a5818ee8d2505bc8d363973eb7072db8871341c51875933e ) [core/doc/admin/configuration_files/external_storage/local.html] => Array ( [expected] => [current] => 005352986fdf9f65e27ff7903bd8507273123f03f1e09e12a191c8e2d9fcb333ec9efcce2c64f296b9d7f65ef3e3abb014add39a9274a07c8dd1a3e03be26c34 ) [core/doc/admin/configuration_files/external_storage/amazons3.html] => Array ( [expected] => [current] => f8d28253ef871e52ad767828a6ca44d97fe8c8b1004204188bd8d4d2376364bd6498b402d635b28e14d1f81255e6768ef03c47801b5f85a0064718656f45bcb4 ) [core/doc/admin/configuration_files/external_storage/sftp.html] => Array ( [expected] => [current] => ed032da5ed1dcccac599ac60e399bea905e3de72be9c5a434c074d27ceaa9ba87093e0c97ab3d0ad4ee0368b7bc6894628c2bac9c37ba044288b0d767da11a9f ) [core/doc/admin/configuration_files/external_storage/smb.html] => Array ( [expected] => [current] => 1e1779e1302860841b7ad0bcb747223b3ae07dc2df8cf0a5b6cb67740a9869909a997e0adcdbbd5e482bb6a8e1bf7e0549d6a8af1aa5eb54b7c708a579135553 ) [core/doc/admin/configuration_files/external_storage/ftp.html] => Array ( [expected] => [current] => f4b2adc6ebbfadc94b1fdf466e28afffc77c958a9cbd549db2f6ebe9ab74b9dc7e739635773e4c605e1f58d5e6ce5e32631bc3f7a68fcebe72871ce8e84a74a6 ) [core/doc/admin/configuration_files/external_storage/openstack.html] => Array ( [expected] => [current] => 00d7eaee76b1446fbb70d5205eb6c50a0399186c15c0cd9e658a763e63b158f7637131f9d44db3adb4fdc8586916de3e5a483a433ca0667bdd06766267045991 ) [core/doc/admin/configuration_files/external_storage/google.html] => Array ( [expected] => [current] => 9ff53b44ec42f88db22de47193f365441cf67680d094033a51a036a033ae1614e253bb687c68e11dcd1a1a2fdb6461e2af4b1930f6cef6f225b124fbf9e05b6a ) [core/doc/admin/configuration_files/external_storage/owncloud.html] => Array ( [expected] => [current] => 9cfd1e3f4f90f59ca12dddb3278e6b8bdfb091487e57ee6d29a9a4f497f1b4cbdfd1efb97cbdbf3e2564b50425cd261ab41e2e9c226a238080bc8d7e0ed4df16 ) [core/doc/admin/configuration_files/external_storage/dropbox.html] => Array ( [expected] => [current] => 7752a50c2de4b76ce64bb153af194e35825429646a8937c041b859bfc885ef4b32287c52e59db19a3d21cf1731a75516cafd45b89cb104dc63957f70cbf1d47d ) [core/doc/admin/configuration_files/external_storage/auth_mechanisms.html] => Array ( [expected] => [current] => 3dcafd2f2c31460fa697049bb372259b34cce833aaec8ac23903e8205bb92d3c2ca0d903dfb79315d2502c0d635944261f8ef91b2cb582bd5781240d3e9acdfc ) [core/doc/admin/configuration_files/file_sharing_configuration.html] => Array ( [expected] => [current] => 00e5fdaaad0c7859ac1e89619b1952984ec31371d1d9dd680030f5b836782808157eeceb8d3b725516ff3f76591a293329a09c83877a9df71977accbf45cbd94 ) [core/doc/admin/configuration_files/default_files_configuration.html] => Array ( [expected] => [current] => ace33bc1dbe99b97ffa1b263f5b74d872915eb2ffbaf45d492027033cdc6b8e6f126a747c6e5119d46ed60a65c318586cd344167a663b757d33fa2720619a11b )
