It reaches end of life soon (May 2017), so you should perhaps plan an upgrade to OC 9.0
The installer script can’t be used, the updater app is not very reliable, a bit more work but better result are obtained with a manual update (please backup all data and database before):
delete everything except for the data/ and config/ folder
extract the new code onto your webserver
run the upgrade (open owncloud in your webbrowser, or if you have terminal access use the occ-command as advised in the manual)
