Hi, I did upgrade to 10.0.8 from 10.0.3 and the system isn’t working properly now.
First problem, when I’m running from CentOS:
sudo -u apache php /var/www/html/owncloud/occ app:list
I’m getting this error: (there is new module to install?)
PHP module intl not installed.
Please ask your server administrator to install the module.
exception ‘Exception’ with message ‘Environment not properly prepared.’ in /var/www/html/owncloud/lib/private/Console/Application.php:135
Stack trace:
#0 /var/www/html/owncloud/console.php(105): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#1 /var/www/html/owncloud/occ(11): require_once(’/var/www/html/o…’)
Second problem is the results of the integrity tests- what are the commands I should run to fix it?
Technical information
them.
Results
- core
- INVALID_HASH
- updater/vendor/autoload.php
- updater/vendor/composer/autoload_real.php
- updater/vendor/composer/autoload_static.php
- updater/vendor/composer/installed.json
- updater/vendor/composer/ClassLoader.php
- INVALID_HASH
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[updater/vendor/autoload.php] => Array
[expected] => 520c2c2cbd83194c8204658e03b587d41277da2ba997530727180710485e897ab2cf9995f66f1c9b000ae4dba527c4e33b371416cb8ee04d7f2fd6901020969d
[current] => c18f36fbde7a747c021f25ecc76cb697d20f93b5b9b20a5b7e21e99ad23fdd07bb82c0e2e328963745325be0ec914ddc474349e6492643aab52ef8a3818e900c
[updater/vendor/composer/autoload_real.php] => Array
[expected] => feee4ae69fcc062c769d6faa8f573cdb8ec4cead1bda7b97b1908ad2d9c6aae28bc34ad4ed8f5dabd30090c51531734f9f0f70b09b793012261927c45e630ba1
[current] => e9ee582aed5ee48589cffc1d739be65750bdbf26727208f96fd39eddc5a552bc484a22baf0dcef37a22490754ccb4b3c2660569278bc5d494a844646aba430c3
[updater/vendor/composer/autoload_static.php] => Array
[expected] => 004831c56c8c3c46f6fa1d5f84e83c86fdbb147e32313705e01579cd8efd5b5fac54643a8af92b71e357d41c6672c441329a3a9dab36a5da257976c10af6f6ec
[current] => 7b4e213c12216a884abb9e5f580e00302fd0898cf88f2bb80fb31cfc22a848479e573afcae8aa7fead6dfa32d5fc0df9d9c9d617fe0bb1e00e31ddb0d1f21c48
[updater/vendor/composer/installed.json] => Array
[expected] => 0213703f26f45e24231ec43aad303bcce3633507b6a3eb5e7e68d86ceb7242bdad345ccc882990fdf0216bb47940e06c4a223955ddebda1e7c3c5340c24dae6f
[current] => 0fb9a6b8e419e3defc1645728360773db2003b2044a9229c6834c976e79ab909d18de232ccd05b17263e7a4522650d8a3debdffa652525da764668a25f1fb489
[updater/vendor/composer/ClassLoader.php] => Array
[expected] => 9acadbf32ca0ee18c534f508f20041bcb7629cb8c7c51ef7b3b967ecd93734ecee3afac65d8fc05116c0894ed39bce85cc3eb6bc65a573955291352d84d779fd
[current] => 68086bbf18985981f367037635e53545daba40f37c9eff9b750ec47cd99df3c8a5bc4fd56a04a0bf6ed32399c972196ec57680614ab16715652a67186b261d73
