- Follow docs for manual upgrade
- run “php occ upgrade” as www
- error message during integrity check
Upgrade process should start and finish without error
Upgrade process fails during integrity check:
PHP Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 2964344 bytes) in /usr/local/www/owncloud/lib/private/IntegrityCheck/Helpers/FileAccessHelper.php on line 42
FreeNAS 11.3-RELEASE-p6 jail
lighttpd-1.4.55_1
MySQL 5.6.49
php 7.2.33
10.5.0.10
Older version, 10.4.1.3
manually from the website; https://owncloud.com/download-server/
https://gist.github.com/FlyingPersian/e6d4601a8fdf66ac0fcba46adce9a4e4
**List of activated apps:**
Apps:
no
### Logs
#### Upgrade Log
https://gist.github.com/FlyingPersian/e341f5ada1eaa310aecadcd702d4a99a
