Upgrade to 3.1.4 on freebsd
hello I wont to upgrade to the new version of owncloud and it gives me the error that the
configuration sould do by command prompt because it is s heavy upgrad
Go to the owncloud directory and start the upgrade from your terminal:
sudo -u www php occ upgrade
https://doc.owncloud.org/server/latest/admin_manual/maintenance/upgrade.html#troubleshooting
the command suites freebsd?
If your webserver user is www, it should be at least similar, I'm not a FreeBSD user.
root@customplugin_1:/ # -u www php occ upgrade
-u: Command not found.
Required
Use update on a command line Because this is a large update.
Help, you can view the documentation.
You forgot sudo in the command from the earlier post https://central.owncloud.org/t/upgrade-to-3-1-4-on-freebsd/5710/2
It a root environment thanks
Yes, but you must not run this command as root.
\root@customplugin_1:/ # sudo -u www php occ upgrade
sudo: Command not found.
sudo also exists for FreeBSD:
https://www.freebsd.org/cgi/man.cgi?query=sudo&manpath=SuSE+Linux/i386+11.3
Please get familiar with a new OS on a local installtion before you consider using it on a public server.
Thanks I think I'll switch to centos7
