- Upgrading and migrating the owncloud from 10.0.7 to 10.4.1
- Currently I am using owncloud 10.0.7 which is running in a server environment and I need to upgrade to latest version of owncloud 10.4.1 and for testing I have installed my ubuntu server in a Virtual Machine Environment in a local PC
- I have tried to take a sqldump in a owncloud 10.0.7 version the table has an empty set.
Owncloud database dump file should have tables
Empty table set in my owncloud database
Operating system : Ubuntu 16.04 Server LTS
Web server: Apache2
Database: Mariadb 10
PHP version: PHP 7.0.
ownCloud version: â10.0.7.2â,
Updated from an older ownCloud or fresh install: Fresh Install
Where did you install ownCloud from: owncloud.org
Login as admin user into your ownCloud and access http://example.com/owncloud/index.php/settings/integrity/failed
paste the results into https: No errors have been found.
âsystemâ: {
âinstanceidâ: âoc3lo3f6rcjdâ,
âpasswordsaltâ: âREMOVED SENSITIVE VALUEâ,
âsecretâ: âREMOVED SENSITIVE VALUEâ,
âtrusted_domainsâ: [
â192.168.1.11â,
âdatadirectoryâ: â/var/www/html/owncloud/dataâ,
âoverwrite.cli.urlâ: âhttps://192.168.1.11/owncloudâ,
âdbtypeâ: âsqlite3â,
âversionâ: â10.0.7.2â,
âlogtimezoneâ: âUTCâ,
âinstalledâ: true,
âmail_smtpmodeâ: âsmtpâ,
âloglevelâ: 1
Enabled:
afterlogic: 1.1.2
comments: 0.3.0
configreport: 0.1.1
contacts: 1.5.4
customgroups: 0.3.6
dav: 0.3.2
federatedfilesharing: 0.3.1
federation: 0.1.0
files: 1.5.1
files_external: 0.7.1
files_external_ftp: 0.2.0
files_pdfviewer: 0.11.0
files_sharing: 0.10.1
files_trashbin: 0.9.1
files_versions: 1.3.0
files_videoplayer: 0.9.8
firstrunwizard: 1.1
gallery: 16.1.0
gpxpod: 2.2.2
groupalert: 1.0.5
guests: 0.5.0
market: 0.2.4
notifications: 0.3.2
onlyoffice: 2.2.1
phonetrack: 0.2.8
provisioning_api: 0.5.0
systemtags: 0.3.0
templateeditor: 0.3
twofactor_backup_codes: 0.0.4
updatenotification: 0.2.1
Disabled:
encryption
external
theme-example
user_external.
Are you using external storage, if yes which one: yes local/smb/sftp/âŚ
Are you using encryption: no
Browser: Apache/2.4.18 (Ubuntu)
Operating system: ubuntu
[Fri Jul 24 14:47:37.282560 2020] [:error] [pid 17108] [client 183.83.241.2:35737] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:48:08.939750 2020] [:error] [pid 17344] [client 183.83.241.2:35756] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:48:09.290535 2020] [:error] [pid 17344] [client 183.83.241.2:35756] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:48:40.918366 2020] [:error] [pid 16179] [client 183.83.241.2:35763] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:48:41.249415 2020] [:error] [pid 16179] [client 183.83.241.2:35763] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:49:12.949405 2020] [:error] [pid 17335] [client 183.83.241.2:35776] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:49:13.324344 2020] [:error] [pid 17335] [client 183.83.241.2:35776] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:49:44.932445 2020] [:error] [pid 15691] [client 183.83.241.2:35800] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:49:45.303921 2020] [:error] [pid 15691] [client 183.83.241.2:35800] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:50:16.926054 2020] [:error] [pid 16143] [client 183.83.241.2:35810] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:50:17.271708 2020] [:error] [pid 16143] [client 183.83.241.2:35810] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:50:48.928660 2020] [:error] [pid 17108] [client 183.83.241.2:35842] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:50:49.281363 2020] [:error] [pid 17108] [client 183.83.241.2:35842] script â/var/www/html/remote.phpâ not found or unable to stat
[Fri Jul 24 14:51:20.950767 2020] [:error] [pid 17335] [client 183.83.241.2:35862] script â/var/www/html/status.phpâ not found or unable to stat
[Fri Jul 24 14:51:21.326396 2020] [:error] [pid 17335] [client 183.83.241.2:35862] script â/var/www/html/remote.phpâ not found or unable to stat
