- Upgrading and migrating the owncloud from 10.0.7 to 10.4.1
- Currently I am using owncloud 10.0.7 which is running in a server environment and I need to upgrade to latest version of owncloud 10.4.1 and for testing I have installed my ubuntu server in a Virtual Machine Environment in a local PC
- I have tried to take a sqldump in a owncloud 10.0.7 version the table has an empty set.
Owncloud database dump file should have tables
Empty table set in my owncloud database
Operating system : Ubuntu 16.04 Server LTS
Web server: Apache2
Database: Mariadb
PHP version: PHP 7.0.
ownCloud version: “10.0.7.2”,
Updated from an older ownCloud or fresh install: Fresh Install
Where did you install ownCloud from: owncloud.org
Login as admin user into your ownCloud and access http://example.com/owncloud/index.php/settings/integrity/failed
paste the results into https: No errors have been found.
“system”: {
“instanceid”: “oc3lo3f6rcjd”,
“trusted_domains”: [
“192.168.1.11”,
“datadirectory”: “/var/www/html/owncloud/data”,
“overwrite.cli.url”: “https://192.168.1.11/owncloud”,
“dbtype”: “sqlite3”,
“version”: “10.0.7.2”,
“logtimezone”: “UTC”,
“installed”: true,
“mail_smtpmode”: “smtp”,
“loglevel”: 1
Enabled:
afterlogic: 1.1.2
comments: 0.3.0
configreport: 0.1.1
contacts: 1.5.4
customgroups: 0.3.6
dav: 0.3.2
federatedfilesharing: 0.3.1
federation: 0.1.0
files: 1.5.1
files_external: 0.7.1
files_external_ftp: 0.2.0
files_pdfviewer: 0.11.0
files_sharing: 0.10.1
files_trashbin: 0.9.1
files_versions: 1.3.0
files_videoplayer: 0.9.8
firstrunwizard: 1.1
gallery: 16.1.0
gpxpod: 2.2.2
groupalert: 1.0.5
guests: 0.5.0
market: 0.2.4
notifications: 0.3.2
onlyoffice: 2.2.1
phonetrack: 0.2.8
provisioning_api: 0.5.0
systemtags: 0.3.0
templateeditor: 0.3
twofactor_backup_codes: 0.0.4
updatenotification: 0.2.1
Disabled:
encryption
external
theme-example
user_external.
Are you using external storage, if yes which one: yes local/smb/sftp/…
Are you using encryption: no
Browser: Apache/2.4.18 (Ubuntu)
Operating system: ubuntu
[Fri Jul 24 14:47:37.282560 2020] [:error] [pid 17108] [client 183.83.241.2:35737] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:48:08.939750 2020] [:error] [pid 17344] [client 183.83.241.2:35756] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:48:09.290535 2020] [:error] [pid 17344] [client 183.83.241.2:35756] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:48:40.918366 2020] [:error] [pid 16179] [client 183.83.241.2:35763] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:48:41.249415 2020] [:error] [pid 16179] [client 183.83.241.2:35763] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:49:12.949405 2020] [:error] [pid 17335] [client 183.83.241.2:35776] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:49:13.324344 2020] [:error] [pid 17335] [client 183.83.241.2:35776] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:49:44.932445 2020] [:error] [pid 15691] [client 183.83.241.2:35800] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:49:45.303921 2020] [:error] [pid 15691] [client 183.83.241.2:35800] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:50:16.926054 2020] [:error] [pid 16143] [client 183.83.241.2:35810] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:50:17.271708 2020] [:error] [pid 16143] [client 183.83.241.2:35810] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:50:48.928660 2020] [:error] [pid 17108] [client 183.83.241.2:35842] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:50:49.281363 2020] [:error] [pid 17108] [client 183.83.241.2:35842] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:51:20.950767 2020] [:error] [pid 17335] [client 183.83.241.2:35862] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:51:21.326396 2020] [:error] [pid 17335] [client 183.83.241.2:35862] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:51:52.927111 2020] [:error] [pid 17854] [client 183.83.241.2:35888] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:51:53.285428 2020] [:error] [pid 17854] [client 183.83.241.2:35888] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:52:24.927819 2020] [:error] [pid 17108] [client 183.83.241.2:35894] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:52:25.287108 2020] [:error] [pid 17108] [client 183.83.241.2:35894] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:52:56.922190 2020] [:error] [pid 17854] [client 183.83.241.2:35933] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:52:57.278308 2020] [:error] [pid 17854] [client 183.83.241.2:35933] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:53:28.928510 2020] [:error] [pid 17724] [client 183.83.241.2:35941] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:53:29.303424 2020] [:error] [pid 17724] [client 183.83.241.2:35941] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:54:00.931843 2020] [:error] [pid 16179] [client 183.83.241.2:35949] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:54:01.295086 2020] [:error] [pid 16179] [client 183.83.241.2:35949] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:54:32.931887 2020] [:error] [pid 17969] [client 183.83.241.2:35964] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:54:33.294222 2020] [:error] [pid 17969] [client 183.83.241.2:35964] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:55:04.921887 2020] [:error] [pid 16179] [client 183.83.241.2:35968] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:55:05.281185 2020] [:error] [pid 16179] [client 183.83.241.2:35968] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:55:36.941676 2020] [:error] [pid 18493] [client 183.83.241.2:35982] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:55:37.327893 2020] [:error] [pid 18493] [client 183.83.241.2:35982] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:56:08.920513 2020] [:error] [pid 18170] [client 183.83.241.2:35986] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:56:09.255521 2020] [:error] [pid 18170] [client 183.83.241.2:35986] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:56:40.942503 2020] [:error] [pid 18505] [client 183.83.241.2:36001] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:56:41.299840 2020] [:error] [pid 18505] [client 183.83.241.2:36001] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:57:12.931189 2020] [:error] [pid 16179] [client 183.83.241.2:36008] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:57:13.300122 2020] [:error] [pid 16179] [client 183.83.241.2:36008] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:57:44.919812 2020] [:error] [pid 16179] [client 183.83.241.2:36016] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:57:45.271907 2020] [:error] [pid 16179] [client 183.83.241.2:36016] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:58:16.930376 2020] [:error] [pid 18496] [client 183.83.241.2:36027] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:58:17.297699 2020] [:error] [pid 18496] [client 183.83.241.2:36027] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:59:03.928843 2020] [:error] [pid 18632] [client 183.83.241.2:36031] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:59:04.290572 2020] [:error] [pid 18632] [client 183.83.241.2:36031] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:59:35.929706 2020] [:error] [pid 19046] [client 183.83.241.2:36075] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:59:36.300010 2020] [:error] [pid 19046] [client 183.83.241.2:36075] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 14:59:52.921117 2020] [:error] [pid 18795] [client 183.83.241.2:36093] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 14:59:53.277006 2020] [:error] [pid 18795] [client 183.83.241.2:36093] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:00:24.937787 2020] [:error] [pid 18496] [client 183.83.241.2:36248] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:00:25.768534 2020] [:error] [pid 18496] [client 183.83.241.2:36248] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:00:57.086126 2020] [:error] [pid 19282] [client 183.83.241.2:36324] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:00:57.626405 2020] [:error] [pid 19282] [client 183.83.241.2:36324] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:01:28.931259 2020] [:error] [pid 19372] [client 183.83.241.2:36351] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:01:29.291836 2020] [:error] [pid 19372] [client 183.83.241.2:36351] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:02:00.921365 2020] [:error] [pid 19438] [client 183.83.241.2:36400] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:02:01.278217 2020] [:error] [pid 19438] [client 183.83.241.2:36400] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:02:32.966551 2020] [:error] [pid 19414] [client 183.83.241.2:36417] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:02:33.424591 2020] [:error] [pid 19414] [client 183.83.241.2:36417] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:03:19.927987 2020] [:error] [pid 19355] [client 183.83.241.2:36473] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:03:20.287363 2020] [:error] [pid 19355] [client 183.83.241.2:36473] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:03:36.957934 2020] [:error] [pid 19572] [client 183.83.241.2:36513] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:03:37.320787 2020] [:error] [pid 19572] [client 183.83.241.2:36513] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:04:08.933582 2020] [:error] [pid 19732] [client 183.83.241.2:36547] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:04:09.302256 2020] [:error] [pid 19732] [client 183.83.241.2:36547] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:04:40.923457 2020] [:error] [pid 19795] [client 183.83.241.2:36586] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:04:41.288261 2020] [:error] [pid 19795] [client 183.83.241.2:36586] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:05:12.933111 2020] [:error] [pid 19523] [client 183.83.241.2:36604] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:05:13.303091 2020] [:error] [pid 19523] [client 183.83.241.2:36604] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:05:59.977950 2020] [:error] [pid 19947] [client 183.83.241.2:36711] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:06:00.341410 2020] [:error] [pid 19947] [client 183.83.241.2:36711] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:06:31.957168 2020] [:error] [pid 19738] [client 183.83.241.2:34824] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:06:32.304163 2020] [:error] [pid 19738] [client 183.83.241.2:34824] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:06:48.939939 2020] [:error] [pid 19434] [client 183.83.241.2:34855] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:06:49.315171 2020] [:error] [pid 19434] [client 183.83.241.2:34855] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:07:20.928497 2020] [:error] [pid 19523] [client 183.83.241.2:34892] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:07:21.297825 2020] [:error] [pid 19523] [client 183.83.241.2:34892] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:07:52.925893 2020] [:error] [pid 20143] [client 183.83.241.2:34923] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:07:53.283969 2020] [:error] [pid 20143] [client 183.83.241.2:34923] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:08:24.938196 2020] [:error] [pid 19840] [client 183.83.241.2:34958] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:08:25.310752 2020] [:error] [pid 19840] [client 183.83.241.2:34958] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:08:56.940730 2020] [:error] [pid 20091] [client 183.83.241.2:34966] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:08:57.317722 2020] [:error] [pid 20091] [client 183.83.241.2:34966] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:09:28.922363 2020] [:error] [pid 20307] [client 183.83.241.2:34995] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:09:29.276087 2020] [:error] [pid 20307] [client 183.83.241.2:34995] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:10:00.924498 2020] [:error] [pid 20307] [client 183.83.241.2:35020] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:10:01.287320 2020] [:error] [pid 20307] [client 183.83.241.2:35020] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:10:32.928224 2020] [:error] [pid 19523] [client 183.83.241.2:35040] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:10:33.283540 2020] [:error] [pid 19523] [client 183.83.241.2:35040] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:11:04.931648 2020] [:error] [pid 19523] [client 183.83.241.2:35075] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:11:05.305474 2020] [:error] [pid 19523] [client 183.83.241.2:35075] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:11:36.923347 2020] [:error] [pid 19737] [client 183.83.241.2:35140] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:11:37.283044 2020] [:error] [pid 19737] [client 183.83.241.2:35140] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:12:08.923448 2020] [:error] [pid 19737] [client 183.83.241.2:35169] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:12:09.265107 2020] [:error] [pid 19737] [client 183.83.241.2:35169] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:12:40.924868 2020] [:error] [pid 20091] [client 183.83.241.2:35226] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:12:41.272374 2020] [:error] [pid 20091] [client 183.83.241.2:35226] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:13:12.925158 2020] [:error] [pid 20091] [client 183.83.241.2:35243] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:13:13.288144 2020] [:error] [pid 20091] [client 183.83.241.2:35243] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:13:59.935587 2020] [:error] [pid 19952] [client 183.83.241.2:35254] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:14:00.305454 2020] [:error] [pid 19952] [client 183.83.241.2:35254] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:15:03.929260 2020] [:error] [pid 19523] [client 183.83.241.2:35359] script ‘/var/www/html/status.php’ not found or unable to stat
[Fri Jul 24 15:15:04.292187 2020] [:error] [pid 19523] [client 183.83.241.2:35359] script ‘/var/www/html/remote.php’ not found or unable to stat
[Fri Jul 24 15:15:41.935317 2020] [:error] [pid 19737] [client 183.83.241.2:35405] script ‘/var/www/html/status.php’ not found or unable to stat
I have upgraded the owncloud version 10.0.7 to 10.4.1 by these steps.
Step 1 : I have installed the owncloud setup by this article
AvoidErrors – 21 Jun 18
I recently installed Ubuntu 18.04 LTS on a mini PC, I decided why don’t we install OwnCloud and use this mini PC as a free cloud storage server. Here are the steps I took that shows how I got OwnCloud installed on Ubuntu. OwnCloud is free robust open…
In this article they didn’t Mention to install the php7.2-sqlite3 after i have installed php7.2-sqlite3 i started to run my owncloud 10.4.1 in an web browser.
Step 2: For migrating the db i stopped the apache service and put my owncloud in an maintenance mode and started replacing the db file.In owncloud 10.0.7 i have copied the sqlite3 source db file and replaced with my current owncloud 10.4.1 sqlite3 db file which exists in /var/www/html/owncloud/data/owncloud.db
Step3 : After i have replaced the owncloud db file i started to upgrade the occ to execute the db file by referring to this article
https://doc.owncloud.org/server/10.4/admin_manual/configuration/server/occ_command.html#apps-commands
Step4: After the upgrade my db file got reflected in my current owncloud 10.4.1 which still has sqlite3 db type and i have synced my data from my previous owncloud 10.0.7
Step 5: I want to convert my database from sqlite3 to mariadb i just referrred this article to convert my db type https://doc.owncloud.com/server/10.2/admin_manual/configuration/database/db_conversion.html
