I just discovered the magic of APCu on my ownCloud servers; I’ve configured it on both test and production, and it’s working great.
Upgrading to V.10 kills that, on my test server. Despite nothing else changing (except the install of v.10 from the repository), I get the error that there’s no memcaching configured.
Has anyone had any issues with this, following an upgrade?
This is on Ubuntu 16.04, PHP7, Apache, and a Previously fully functional version of OC 9.1.4.
Hey @evo5150 thank you for reporting this.
Could you please provide the developers a filled out issue template on Sign in to GitHub · GitHub
Please also specify your apcu configuration.
- Installed APCu on 9.1.4, and configured config.php. Works fine.
- Installed v.10.0 from repositories; then get error in Admin page that no caching configured
- revert virtual machine snapshot back to 9.1.4, and it is working again
APCu caching should work
APCu caching in v.10.0 doesn’t work
Operating system: Ubuntu Server 16.04LTS
Web server: Apache
PHP version: 7.0
ownCloud version: (see ownCloud admin page) v.10.0
Updated from an older ownCloud or fresh install: update from 9.1.4
Where did you install ownCloud from: Repositories located on SuSe
No
No
I filled it out the best I could; some of it wouldn’t have been helpful, since I’ve reverted back to v.9.1.4.
Please create a new issue at Sign in to GitHub · GitHub instead.
