- fresh Install owncloud 10.0.9 on fresh install of centos 7
- Mount remote storage to data directory folder
- copy backed up files of data folder files back onto remote storage
- run httpd
- setup and run owncloud for first time
be able to see files uploaded with proper name
files upload but don’t rename therefore do not show up in web gui
error flashes at top in yellow: could not rename part file to final file
centos
apache
mysql
10.0.9
fresh install
zip from website
https://gist.github.com/jeremybrown82/19b920c378f68e767a16bfd483fdafa9#file-gistfile1-txt
"system": {
"instanceid": "ocveemviq2ey",
"trusted_domains": [
"owndrivecloud.com"
"datadirectory": "\/var\/www\/html\/owncloud\/data",
"overwrite.cli.url": "http:\/\/owndrivecloud.com\/owncloud",
"dbtype": "mysql",
"version": "10.0.9.5",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true
**List of activated apps:**
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.4
- notifications: 0.3.4
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- user_external
b2 backblaze bucket
yes
no
### Client configuration
**Browser:**
latest firefox
**Operating system:**
windows 10
