I’m using version 10.0.9
I cannot see any of the versions in the details view of the browser. I get the message “No other versions available.” I can see the versions on the server in the respective files_versions folders.
This looks like a bug that was fixed in version 5 but I can find nothing recent to help. Any suggestions?
Eric
Check if the versions exist in the oc_filecache table.
Note that versions are always attached to the owner’s storage in a sharing scenario.
I don’t seem to be able to access mysql. I found the username/password combination in /owncloud/config/config.php but get an ‘access denied’ message when attempting to connect
Any idea on how your owncloud instance can access with this credentials?
