I am having issues are I have deployed owncloud via the provided OVA.
It goes through the setup alright, I can browse to the login and log in to the management interface.
But when I click on Applications -> Owncloud I just get a 404 /owncloud.
I have had a read around and the only issues I can find for this is relating to upgrades.
I also have no idea where anything is installed on the server as it looks to use Docker? Never used it.
- Login to management portal
- Click on Applications -> OwnCloud
- Get the error The requested URL /owncloud was not found on this server.
I was hoping it would take me to a webpage so I could configure stuff
Receive a 404
I have deployed the latest OVA for ESX 10.0.3
**Web server: No idea, whatever is installed as part of the OVA
**Database:No idea, whatever is installed as part of the OVA
**PHP version:No idea, whatever is installed as part of the OVA
**ownCloud version:10.0.3
**Updated from an older ownCloud or fresh install:Fresh Install
**Where did you install ownCloud from:
Not Found
The requested URL /index.php/settings/integrity/failed was not found on this server.
I cannot see these options.........
I have no idea where it is installed........that is why I used the OVA, I am not a big linux user.
No idea where it is installed
**Are you using external storage, if yes which one:NO
**Are you using encryption:NO
**Are you using an external user-backend, if yes which one:AD
Chrome
**Operating system:No idea, deployed from OVA
