Hi I’m using 10.0.8 installed with docker. I’m trying to save my data on a place outside of the container.
In the docker-compose.yml:
volumes:
files:/mnt/data
/data/VolumeOutsideContainer:/mnt/data
If I type :
volumes:
files: /data/VolumeOutsideContainer
It saves it on the struct /data/VolumeOutsideContainer
inside the container.
This doesn’t work. In my mind this is all I should be needing to save the datafiles outsinde the container. Does somebody else have an input?
