im struggling around with this problem and searched a lot. I hope someone of you could help me.
I've made a fresh install on owncloud everything is working fine, but I get the warning that the web-dav interface isnt working properly. My sync client work at least for smaler files, if i try to upload bigger (more than 5MB or so) it says connection closed. I think that this is server sided, and also in realation with the web-dav.
Operating system: openSUSE Leap 42.3
Web server: apache2 v2.4.23
Database: MariaDB 10.0.32
PHP version: 7.0.7
ownCloud version: 10.0.6
Where did you install ownCloud from: manual from tar archiv
"config": {
"instanceid": "ocwm59ehvxog",
"trusted_domains": [
"cloud.mydoamin.de"
"datadirectory": "\/srv\/ocdata",
"overwrite.cli.url": "https:\/\/cloud.mydoamin.de",
"dbtype": "mysql",
"version": "10.0.6.1",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"fililocking.enabled": true,
"memcache.locking": "\\OC\\Memcache\\APCu",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "ssl",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"mail_smtpport": "465",
"mail_smtppassword": "***REMOVED SENSITIVE VALUE***"
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_texteditor: 2.2.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.3
- notifications: 0.3.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.2
- updatenotification: 0.2.1
- user_ldap: 0.10.0
Disabled:
- encryption
- external
- theme-example
- user_external
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
yes (ActiveDirectory)
LDAP configuration
| Configuration | |
| hasMemberOfFilterSupport | 1 |
| hasPagedResultSupport | |
| homeFolderNamingRule | |
| lastJpegPhotoLookup | 0 |
| ldapAgentName | CN=ldap,OU=Service,OU=******,DC=alderaan,DC=local |
| ldapAgentPassword | *** |
| ldapAttributesForGroupSearch | |
| ldapAttributesForUserSearch | |
| ldapBackupHost | ldap://yavin.alderaan.local |
| ldapBackupPort | 389 |
| ldapBase | DC=alderaan,DC=local |
| ldapBaseGroups | DC=alderaan,DC=local |
| ldapBaseUsers | DC=alderaan,DC=local |
| ldapCacheTTL | 600 |
| ldapConfigurationActive | 1 |
| ldapDynamicGroupMemberURL | |
| ldapEmailAttribute | |
| ldapExperiencedAdmin | 0 |
| ldapExpertUUIDGroupAttr | |
| ldapExpertUUIDUserAttr | objectguid |
| ldapExpertUsernameAttr | cn |
| ldapGroupDisplayName | cn |
| ldapGroupFilter | |
| ldapGroupFilterGroups | |
| ldapGroupFilterMode | 0 |
| ldapGroupFilterObjectclass | |
| ldapGroupMemberAssocAttr | uniqueMember |
| ldapHost | ldap://naboo.alderaan.local |
| ldapIgnoreNamingRules | |
| ldapLoginFilter | (&(&(|(objectclass=person))(|(|(memberof=CN=Domänen-Benutzer,CN=Users,DC=alderaan,DC=local)(primaryGroupID=513))))(|(samaccountname=%uid)(|(cn=%uid)))) |
| ldapLoginFilterAttributes | cn |
| ldapLoginFilterEmail | 0 |
| ldapLoginFilterMode | 0 |
| ldapLoginFilterUsername | 1 |
| ldapNestedGroups | 0 |
| ldapOverrideMainServer | |
| ldapPagingSize | 500 |
| ldapPort | 389 |
| ldapQuotaAttribute | |
| ldapQuotaDefault | |
| ldapTLS | 0 |
| ldapUserDisplayName | displayName |
| ldapUserDisplayName2 | |
| ldapUserFilter | (&(|(objectclass=person))(|(|(memberof=CN=Domänen-Benutzer,CN=Users,DC=alderaan,DC=local)(primaryGroupID=513)))) |
| ldapUserFilterGroups | Domänen-Benutzer |
| ldapUserFilterMode | 0 |
| ldapUserFilterObjectclass | person |
| ldapUuidGroupAttribute | auto |
| ldapUuidUserAttribute | auto |
| turnOffCertCheck | 0 |
| useMemberOfToDetectMembership | 1 |
Browser: Firefox 58.0.1 (64-Bit)
Operating system: Windows 10 Pro (1709)
