My Owncloud runs on a hosted server of Host Europe.
This is the second time the updater is terminating with the same error: In the past I tried using the updater to upgrade from 9.1.2 to 10.0.4 and finally had to do a manual upgrade. This time I am trying to update from 10.0.4 to 10.0.6 which really should not be a problem... but I get the same behaviour (details see below).
Looking at the logs there might be a problem with the access/rights? ... Can anybody help me?
- Login as administrator.
- Go to Settings / General.
- Start the updater.
Update the owncloud server to version 10.0.6
A blank page is shown with the message "cURL error 7: Failed to connect to localhost port 443: Connection refused"
Web server: Debian 8.0 / Apache 2.4.10
Database:SQL-Lite
PHP version:7.0
ownCloud version: 10.0.4
Updated from an older ownCloud or fresh install:fresh manual install
Where did you install ownCloud from:from the official oc webpage: downloaded package "owncloud-10.0.4.zip"
"basic": {
"license key": "***REMOVED SENSITIVE VALUE***",
"date": "Fri, 02 Feb 2018 12:58:22 +0000",
"ownCloud version": "10.0.4.4",
"ownCloud version string": "10.0.4",
"ownCloud edition": "Community",
"server OS": "Linux",
"server OS version": "Linux vwp3775 4.4.74-1-xenu-static-he+1+ #2 SMP Mon Jun 26 12:35:59 CEST 2017 x86_64",
"server SAPI": "apache2handler",
"webserver version": "Apache",
"hostname": "superfein.de",
"user count": 2,
"user directories": 2,
"logged-in user": "Administrator"
"config": {
"instanceid": "oc7yxjgaci7k",
"trusted_domains": [
"superfein.de"
"datadirectory": "\/is\/htdocs\/wp12439138_SUVXMA4CNM\/www\/owncloud\/data",
"overwrite.cli.url": "https:\/\/superfein.de\/owncloud",
"dbtype": "sqlite3",
"version": "10.0.4.4",
"logtimezone": "UTC",
"installed": true,
"mail_smtpmode": "smtp",
"mail_from_address": "webmaster",
"mail_smtpauthtype": "PLAIN",
"mail_smtpauth": 1,
"mail_domain": "superfein.de",
"mail_smtphost": "vwp3775.webpack.hosteurope.de",
"loglevel": 2,
"maintenance": false,
"updater.secret": "***REMOVED SENSITIVE VALUE***"
"integritychecker": {
"passing": true,
"enabled": true,
"result": []
"core": {
"installedat": "1491382017.6052",
"lastupdatedat": "1517574711",
"public_files": "files_sharing\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"lastcron": "1517575501",
"lastupdateResult": "{\"version\":\"10.0.6\",\"versionstring\":\"ownCloud 10.0.6\",\"url\":\"https:\\\/\\\/download.owncloud.org\\\/community\\\/owncloud-10.0.6.zip\",\"web\":\"https:\\\/\\\/doc.owncloud.org\\\/server\\\/10.0\\\/admin_manual\\\/maintenance\\\/upgrade.html\"}",
"updater.secret.created": "1517575227",
"shareapi_allow_links": "no",
"shareapi_enabled": "no",
"vendor": "owncloud",
"backgroundjobs_mode": "cron"
"apps": [
***SHORTENED***
"phpinfo": {
"apache2handler": {
"Apache Version": "Apache",
"Apache API Version": "20120211",
"Server Administrator": "webmaster@superfein.de",
"Hostname:Port": "superfein.de:0",
"User\/Group": "nobody(65534)\/65534",
"Max Requests": "Per Child: 15200 - Keep Alive: on - Max Per Connection: 100",
"Timeouts": "Connection: 300 - Keep-Alive: 5",
"Virtual Server": "Yes",
"Server Root": "\/etc\/httpd",
"Loaded Modules": "core mod_so mod_watchdog http_core mod_log_config mod_logio mod_version mod_unixd mod_rewrite mod_php7 mod_cgi mod_dav mod_dav_fs mod_include mod_actions mod_cache mod_cache_disk mod_proxy mod_proxy_http mod_ssl mod_auth_basic mod_auth_digest mod_authz_user mod_authz_groupfile mod_authn_core mod_authn_file mod_access_compat mod_authz_core mod_authz_host prefork mpm_itk mod_deflate mod_mime_magic mod_autoindex mod_mime mod_negotiation mod_alias mod_setenvif mod_dir mod_env mod_headers mod_filter mod_expires mod_hestatus mod_rpaf-2",
"engine": "1",
"last_modified": "0",
"xbithack": "0"
"Apache Environment": {
"HTTP_AUTHORIZATION": "no value",
"HTTPS": "on",
"HOME": "\/is\/htdocs\/wp12439138_SUVXMA4CNM\/",
"USER": "wp12439138",
"modHeadersAvailable": "true",
"htaccessWorking": "true",
"HTTP_HOST": "superfein.de",
"HTTP_X_REAL_IP": "94.221.119.147",
"HTTP_X_FORWARDED_FOR": "94.221.119.147",
"HTTP_CONNECTION": "close",
"HTTP_USER_AGENT": "Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:58.0) Gecko\/20100101 Firefox\/58.0",
"HTTP_ACCEPT": "text\/html,application\/xhtml+xml,application\/xml;q=0.9,*\/*;q=0.8",
"HTTP_ACCEPT_LANGUAGE": "de,en-US;q=0.7,en;q=0.3",
"HTTP_ACCEPT_ENCODING": "gzip, deflate, br",
"HTTP_UPGRADE_INSECURE_REQUESTS": "1",
"SERVER_SIGNATURE": "no value",
"SERVER_SOFTWARE": "Apache",
"SERVER_NAME": "superfein.de",
"SERVER_ADDR": "127.0.0.70",
"SERVER_PORT": "443",
"REMOTE_ADDR": "94.221.119.147",
"DOCUMENT_ROOT": "\/is\/htdocs\/wp12439138_SUVXMA4CNM\/www\/",
"REQUEST_SCHEME": "https",
"CONTEXT_PREFIX": "no value",
"CONTEXT_DOCUMENT_ROOT": "\/is\/htdocs\/wp12439138_SUVXMA4CNM\/www\/",
"SERVER_ADMIN": "webmaster@superfein.de",
"SCRIPT_FILENAME": "\/is\/htdocs\/wp12439138_SUVXMA4CNM\/www\/owncloud\/index.php",
"REMOTE_PORT": "51934",
"GATEWAY_INTERFACE": "CGI\/1.1",
"SERVER_PROTOCOL": "HTTP\/1.0",
"REQUEST_METHOD": "GET",
"QUERY_STRING": "no value",
"REQUEST_URI": "\/owncloud\/index.php\/apps\/configreport\/report",
"SCRIPT_NAME": "\/owncloud\/index.php",
"PATH_INFO": "\/apps\/configreport\/report",
"PATH_TRANSLATED": "redirect:\/shopware.php\/configreport\/report"
"HTTP Headers Information": {
"HTTP Request": "GET \/owncloud\/index.php\/apps\/configreport\/report HTTP\/1.0",
"Host": "superfein.de",
"X-Real-IP": "94.221.119.147",
"X-Forwarded-For": "94.221.119.147",
"Connection": "close",
"User-Agent": "Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:58.0) Gecko\/20100101 Firefox\/58.0",
"Accept": "text\/html,application\/xhtml+xml,application\/xml;q=0.9,*\/*;q=0.8",
"Accept-Language": "de,en-US;q=0.7,en;q=0.3",
"Accept-Encoding": "gzip, deflate, br",
"Upgrade-Insecure-Requests": "1",
"Expires": "Thu, 19 Nov 1981 08:52:00 GMT",
"Cache-Control": "no-store, no-cache, must-revalidate",
"Pragma": "no-cache",
"Content-Security-Policy": "default-src self ; script-src self unsafe-eval ; style-src self unsafe-inline ; frame-src *; img-src * data: blob:; font-src self data:; media-src *; connect-src *"
"apcu": {
"Version": "5.1.8",
"APCu Debugging": "Disabled",
"MMAP Support": "Enabled",
"MMAP File Mask": "no value",
"Serialization Support": "php",
"Build Date": "Jan 5 2018 10:42:36",
"apc.coredump_unmap": "Off",
"apc.enable_cli": "Off",
"apc.enabled": "On",
"apc.entries_hint": "4096",
"apc.gc_ttl": "3600",
"apc.mmap_file_mask": "no value",
"apc.preload_path": "no value",
"apc.serializer": "php",
"apc.shm_segments": "1",
"apc.shm_size": "100M",
"apc.slam_defense": "Off",
"apc.smart": "0",
"apc.ttl": "0",
"apc.use_request_time": "On",
"apc.writable": "\/tmp"
"bcmath": {
"BCMath support": "enabled",
"bcmath.scale": "0"
"bz2": {
"BZip2 Support": "Enabled",
"Stream Wrapper support": "compress.bzip2:\/\/",
"Stream Filter support": "bzip2.decompress, bzip2.compress",
"BZip2 Version": "1.0.6, 6-Sept-2010"
"calendar": {
"Calendar support": "enabled"
"Core": {
"PHP Version": "7.0.27-he.0",
"allow_url_fopen": "On",
"allow_url_include": "Off",
"arg_separator.input": "&",
"arg_separator.output": "&",
"auto_append_file": "no value",
"auto_globals_jit": "On",
"auto_prepend_file": "no value",
"browscap": "no value",
"default_charset": "UTF-8",
"default_mimetype": "text\/html",
"disable_classes": "no value",
"disable_functions": "syslog",
"display_errors": [
"Off",
"On"
"display_startup_errors": "Off",
"doc_root": "no value",
"docref_ext": "no value",
"docref_root": "no value",
"enable_dl": "Off",
"enable_post_data_reading": "On",
"error_append_string": "no value",
"error_log": "no value",
"error_prepend_string": "no value",
"error_reporting": [
"32767",
"22527"
"exit_on_timeout": "Off",
"expose_php": "Off",
"extension_dir": "\/usr\/lib\/php7.0\/20151012\/",
"file_uploads": "On",
"highlight.comment": "#FF8000",
"highlight.default": "#0000BB",
"highlight.html": "#000000",
"highlight.keyword": "#007700",
"highlight.string": "#DD0000",
"html_errors": "On",
"ignore_repeated_errors": "Off",
"ignore_repeated_source": "Off",
"ignore_user_abort": "Off",
"implicit_flush": "Off",
"input_encoding": "no value",
"internal_encoding": "no value",
"log_errors": [
"On",
"Off"
"log_errors_max_len": "1024",
"mail.add_x_header": "Off",
"mail.force_extra_parameters": "no value",
"mail.log": "no value",
"max_execution_time": [
"3600",
"30"
"max_file_uploads": "50",
"max_input_nesting_level": "64",
"max_input_time": "60",
"max_input_vars": [
"6144",
"1000"
"memory_limit": [
"512M",
"256M"
"open_basedir": "no value",
"output_buffering": [
"0",
"no value"
"output_encoding": "no value",
"output_handler": "no value",
"post_max_size": [
"513M",
"32M"
"precision": "14",
"realpath_cache_size": "5M",
"realpath_cache_ttl": "300",
"register_argc_argv": "On",
"report_memleaks": "On",
"report_zend_debug": "On",
"request_order": "GP",
"sendmail_from": "no value",
"sendmail_path": "\/usr\/sbin\/sendmail -t -i ",
"serialize_precision": "100",
"short_open_tag": "On",
"SMTP": "localhost",
"smtp_port": "25",
"sql.safe_mode": "Off",
"sys_temp_dir": "no value",
"track_errors": "Off",
"unserialize_callback_func": "no value",
"upload_max_filesize": [
"513M",
"32M"
"upload_tmp_dir": [
"\/is\/htdocs\/user_tmp\/wp12439138_SUVXMA4CNM",
"\/tmp"
"user_dir": "no value",
"user_ini.cache_ttl": "300",
"user_ini.filename": ".user.ini",
"variables_order": "EGPCS",
"xmlrpc_error_number": "0",
"xmlrpc_errors": "Off",
"zend.assertions": "1",
"zend.detect_unicode": "On",
"zend.enable_gc": "On",
"zend.multibyte": "Off",
"zend.script_encoding": "no value"
"ctype": {
"ctype functions": "enabled"
"curl": {
"cURL support": "enabled",
"cURL Information": "7.38.0",
"Age": "3",
"Features": null,
"AsynchDNS": "Yes",
"CharConv": "No",
"Debug": "No",
"GSS-Negotiate": "No",
"IDN": "Yes",
"IPv6": "Yes",
"krb4": "No",
"Largefile": "Yes",
"libz": "Yes",
"NTLM": "Yes",
"NTLMWB": "Yes",
"SPNEGO": "Yes",
"SSL": "Yes",
"SSPI": "No",
"TLS-SRP": "Yes",
"HTTP2": "No",
"GSSAPI": "Yes",
"Protocols": "dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtmp, rtsp, scp, sftp, smtp, smtps, telnet, tftp",
"Host": "x86_64-pc-linux-gnu",
"SSL Version": "OpenSSL\/1.0.1t",
"ZLib Version": "1.2.8",
"libSSH Version": "libssh2\/1.4.3"
"date": {
"date\/time support": "enabled",
"timelib version": "2016.02",
""Olson" Timezone Database Version": "2017.3",
"Timezone Database": "internal",
"Default timezone": "UTC",
"date.default_latitude": "31.7667",
"date.default_longitude": "35.2333",
"date.sunrise_zenith": "90.583333",
"date.sunset_zenith": "90.583333",
"date.timezone": "Europe\/Berlin"
"dba": {
"DBA support": "enabled",
"Supported handlers": "gdbm cdb cdb_make db4 inifile flatfile",
"dba.default_handler": "flatfile"
"dom": {
"DOM\/XML": "enabled",
"DOM\/XML API Version": "20031129",
"libxml Version": "2.9.1",
"HTML Support": "enabled",
"XPath Support": "enabled",
"XPointer Support": "enabled",
"Schema Support": "enabled",
"RelaxNG Support": "enabled"
"exif": {
"EXIF Support": "enabled",
"EXIF Version": "7.0.27-he.0",
"Supported EXIF Version": "0220",
"Supported filetypes": "JPEG,TIFF",
"exif.decode_jis_intel": "JIS",
"exif.decode_jis_motorola": "JIS",
"exif.decode_unicode_intel": "UCS-2LE",
"exif.decode_unicode_motorola": "UCS-2BE",
"exif.encode_jis": "no value",
"exif.encode_unicode": "ISO-8859-15"
"fileinfo": {
"fileinfo support": "enabled",
"version": "1.0.5",
"libmagic": "522"
"filter": {
"Input Validation and Filtering": "enabled",
"Revision": "$Id: 28fcca4bfda9c9907588a64d245b49cb398249d8 $",
"filter.default": "unsafe_raw",
"filter.default_flags": "no value"
"ftp": {
"FTP support": "enabled",
"FTPS support": "enabled"
"gd": {
"GD Support": "enabled",
"GD Version": "bundled (2.1.0 compatible)",
"FreeType Support": "enabled",
"FreeType Linkage": "with freetype",
"FreeType Version": "2.5.2",
"GIF Read Support": "enabled",
"GIF Create Support": "enabled",
"JPEG Support": "enabled",
"libJPEG Version": "6b",
"PNG Support": "enabled",
"libPNG Version": "1.2.50",
"WBMP Support": "enabled",
"XPM Support": "enabled",
"libXpm Version": "30411",
"XBM Support": "enabled",
"gd.jpeg_ignore_warning": [
"1",
"0"
"geoip": {
"geoip extension version": "1.1.1",
"geoip library version": "1006002",
"geoip.custom_directory": "no value"
"gettext": {
"GetText Support": "enabled"
"hash": {
"hash support": "enabled",
"Hashing Engines": "md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5",
"MHASH support": "Enabled",
"MHASH API Version": "Emulated Support"
"iconv": {
"iconv support": "enabled",
"iconv implementation": "glibc",
"iconv library version": "2.19",
"iconv.input_encoding": "no value",
"iconv.internal_encoding": "no value",
"iconv.output_encoding": "no value"
"imagick": {
"imap": {
"IMAP c-Client Version": "2007f",
"SSL Support": "enabled",
"Kerberos Support": "enabled"
"intl": {
"version": "1.1.0",
"ICU version": "52.1",
"ICU Data version": "52.1",
"intl.default_locale": "no value",
"intl.error_level": "0",
"intl.use_exceptions": "0"
"json": {
"json support": "enabled",
"json version": "1.4.0"
"ldap": {
"LDAP Support": "enabled",
"RCS Version": "$Id: cec20da3ccaa477662b8667bef021291fb5bf6f4 $",
"Total Links": "0\/unlimited",
"API Version": "3001",
"Vendor Name": "OpenLDAP",
"Vendor Version": "20440",
"SASL Support": "Enabled",
"ldap.max_links": "Unlimited"
"libxml": {
"libXML support": "active",
"libXML Compiled Version": "2.9.1",
"libXML Loaded Version": "20901",
"libXML streams": "enabled"
"mbstring": {
"Multibyte Support": "enabled",
"Multibyte string engine": "libmbfl",
"HTTP input encoding translation": "disabled",
"libmbfl version": "1.3.2",
"oniguruma version": "5.9.5",
"Multibyte (japanese) regex support": "enabled",
"Multibyte regex (oniguruma) version": "5.9.5",
"mbstring.detect_order": "no value",
"mbstring.encoding_translation": "Off",
"mbstring.func_overload": "0",
"mbstring.http_input": "no value",
"mbstring.http_output": "no value",
"mbstring.http_output_conv_mimetypes": "^(text\/|application\/xhtml\\+xml)",
"mbstring.internal_encoding": "no value",
"mbstring.language": "neutral",
"mbstring.strict_detection": "Off",
"mbstring.substitute_character": "no value"
"mcrypt": {
"Version": "2.5.8",
"Api No": "20021217",
"Supported ciphers": "cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes",
"Supported modes": "cbc cfb ctr ecb ncfb nofb ofb stream",
"mcrypt.algorithms_dir": "no value",
"mcrypt.modes_dir": "no value"
"mysqli": {
"Client API library version": "mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $",
"Active Persistent Links": "0",
"Inactive Persistent Links": "0",
"Active Links": "0",
"mysqli.allow_local_infile": "On",
"mysqli.allow_persistent": "On",
"mysqli.default_host": "no value",
"mysqli.default_port": "3306",
"mysqli.default_pw": "no value",
"mysqli.default_socket": "\/var\/run\/mysqld\/mysqld.sock",
"mysqli.default_user": "no value",
"mysqli.max_links": "50",
"mysqli.max_persistent": "Unlimited",
"mysqli.reconnect": "Off",
"mysqli.rollback_on_cached_plink": "Off"
"mysqlnd": {
"Version": "mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $",
"Compression": "supported",
"core SSL": "supported",
"extended SSL": "supported",
"Command buffer size": "4096",
"Read buffer size": "32768",
"Read timeout": "31536000",
"Collecting statistics": "Yes",
"Collecting memory statistics": "No",
"Tracing": "n\/a",
"Loaded plugins": "mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_sha256_password",
"API Extensions": "mysqli,pdo_mysql",
"bytes_sent": "0",
"bytes_received": "0",
"packets_sent": "0",
"packets_received": "0",
"protocol_overhead_in": "0",
"protocol_overhead_out": "0",
"bytes_received_ok_packet": "0",
"bytes_received_eof_packet": "0",
"bytes_received_rset_header_packet": "0",
"bytes_received_rset_field_meta_packet": "0",
"bytes_received_rset_row_packet": "0",
"bytes_received_prepare_response_packet": "0",
"bytes_received_change_user_packet": "0",
"packets_sent_command": "0",
"packets_received_ok": "0",
"packets_received_eof": "0",
"packets_received_rset_header": "0",
"packets_received_rset_field_meta": "0",
"packets_received_rset_row": "0",
"packets_received_prepare_response": "0",
"packets_received_change_user": "0",
"result_set_queries": "0",
"non_result_set_queries": "0",
"no_index_used": "0",
"bad_index_used": "0",
"slow_queries": "0",
"buffered_sets": "0",
"unbuffered_sets": "0",
"ps_buffered_sets": "0",
"ps_unbuffered_sets": "0",
"flushed_normal_sets": "0",
"flushed_ps_sets": "0",
"ps_prepared_never_executed": "0",
"ps_prepared_once_executed": "0",
"rows_fetched_from_server_normal": "0",
"rows_fetched_from_server_ps": "0",
"rows_buffered_from_client_normal": "0",
"rows_buffered_from_client_ps": "0",
"rows_fetched_from_client_normal_buffered": "0",
"rows_fetched_from_client_normal_unbuffered": "0",
"rows_fetched_from_client_ps_buffered": "0",
"rows_fetched_from_client_ps_unbuffered": "0",
"rows_fetched_from_client_ps_cursor": "0",
"rows_affected_normal": "0",
"rows_affected_ps": "0",
"rows_skipped_normal": "0",
"rows_skipped_ps": "0",
"copy_on_write_saved": "0",
"copy_on_write_performed": "0",
"command_buffer_too_small": "0",
"connect_success": "0",
"connect_failure": "0",
"connection_reused": "0",
"reconnect": "0",
"pconnect_success": "0",
"active_connections": "0",
"active_persistent_connections": "0",
"explicit_close": "0",
"implicit_close": "0",
"disconnect_close": "0",
"in_middle_of_command_close": "0",
"explicit_free_result": "0",
"implicit_free_result": "0",
"explicit_stmt_close": "0",
"implicit_stmt_close": "0",
"mem_emalloc_count": "0",
"mem_emalloc_amount": "0",
"mem_ecalloc_count": "0",
"mem_ecalloc_amount": "0",
"mem_erealloc_count": "0",
"mem_erealloc_amount": "0",
"mem_efree_count": "0",
"mem_efree_amount": "0",
"mem_malloc_count": "0",
"mem_malloc_amount": "0",
"mem_calloc_count": "0",
"mem_calloc_amount": "0",
"mem_realloc_count": "0",
"mem_realloc_amount": "0",
"mem_free_count": "0",
"mem_free_amount": "0",
"mem_estrndup_count": "0",
"mem_strndup_count": "0",
"mem_estndup_count": "0",
"mem_strdup_count": "0",
"proto_text_fetched_null": "0",
"proto_text_fetched_bit": "0",
"proto_text_fetched_tinyint": "0",
"proto_text_fetched_short": "0",
"proto_text_fetched_int24": "0",
"proto_text_fetched_int": "0",
"proto_text_fetched_bigint": "0",
"proto_text_fetched_decimal": "0",
"proto_text_fetched_float": "0",
"proto_text_fetched_double": "0",
"proto_text_fetched_date": "0",
"proto_text_fetched_year": "0",
"proto_text_fetched_time": "0",
"proto_text_fetched_datetime": "0",
"proto_text_fetched_timestamp": "0",
"proto_text_fetched_string": "0",
"proto_text_fetched_blob": "0",
"proto_text_fetched_enum": "0",
"proto_text_fetched_set": "0",
"proto_text_fetched_geometry": "0",
"proto_text_fetched_other": "0",
"proto_binary_fetched_null": "0",
"proto_binary_fetched_bit": "0",
"proto_binary_fetched_tinyint": "0",
"proto_binary_fetched_short": "0",
"proto_binary_fetched_int24": "0",
"proto_binary_fetched_int": "0",
"proto_binary_fetched_bigint": "0",
"proto_binary_fetched_decimal": "0",
"proto_binary_fetched_float": "0",
"proto_binary_fetched_double": "0",
"proto_binary_fetched_date": "0",
"proto_binary_fetched_year": "0",
"proto_binary_fetched_time": "0",
"proto_binary_fetched_datetime": "0",
"proto_binary_fetched_timestamp": "0",
"proto_binary_fetched_string": "0",
"proto_binary_fetched_json": "0",
"proto_binary_fetched_blob": "0",
"proto_binary_fetched_enum": "0",
"proto_binary_fetched_set": "0",
"proto_binary_fetched_geometry": "0",
"proto_binary_fetched_other": "0",
"init_command_executed_count": "0",
"init_command_failed_count": "0",
"com_quit": "0",
"com_init_db": "0",
"com_query": "0",
"com_field_list": "0",
"com_create_db": "0",
"com_drop_db": "0",
"com_refresh": "0",
"com_shutdown": "0",
"com_statistics": "0",
"com_process_info": "0",
"com_connect": "0",
"com_process_kill": "0",
"com_debug": "0",
"com_ping": "0",
"com_time": "0",
"com_delayed_insert": "0",
"com_change_user": "0",
"com_binlog_dump": "0",
"com_table_dump": "0",
"com_connect_out": "0",
"com_register_slave": "0",
"com_stmt_prepare": "0",
"com_stmt_execute": "0",
"com_stmt_send_long_data": "0",
"com_stmt_close": "0",
"com_stmt_reset": "0",
"com_stmt_set_option": "0",
"com_stmt_fetch": "0",
"com_deamon": "0",
"bytes_received_real_data_normal": "0",
"bytes_received_real_data_ps": "0"
"openssl": {
"OpenSSL support": "enabled",
"OpenSSL Library Version": "OpenSSL 1.0.1t 3 May 2016",
"OpenSSL Header Version": "OpenSSL 1.0.1k 8 Jan 2015",
"Openssl default config": "\/usr\/lib\/ssl\/openssl.cnf",
"openssl.cafile": "no value",
"openssl.capath": "no value"
***SHORTENED****
Are you using encryption: no
Browser: Firefox 58
Operating system: Windows 10
{"reqId":"oEp0pB9XOY2qv7n0dCpK","level":2,"time":"2018-02-02T12:25:06+00:00","remoteAddr":"87.230.47.14","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/occ\/config:list","message":"Invalid request to occ controller. Details: \"Web executor is not allowed to run from a host 87.230.47.14\""}
{"reqId":"u4L74iPJaWQaXKNWogWv","level":3,"time":"2018-02-02T12:25:20+00:00","remoteAddr":"94.221.119.147","user":"mh","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/settings\/admin?sectionid=general","message":"opendir(\/is\/htdocs\/wp12439138_SUVXMA4CNM\/www\/owncloud\/themes): failed to open dir: No such file or directory at \/is\/htdocs\/wp12439138_SUVXMA4CNM\/www\/owncloud\/apps\/templateeditor\/lib\/mailtemplate.php#155"}
*87.230.47.14 is the IP of the server where OC is installed.
*94.221.119.147 is the current IP of my remote laptop from where I run the web interface.
*The folder "themes" does not exist under "/is/htdocs/wp12439138_SUVXMA4CNM/www/owncloud/", but is also not included in the original downloaded package (owncloud-10.0.4.zip)
[Fri Feb 02 13:25:21 2018] [authz_core:error] [pid 7892] [client 94.221.119.147] [host superfein.de] AH01630: client denied by server configuration: /is/htdocs/wp12439138_SUVXMA4CNM/www/owncloud/data/htaccesstest.txt
*htaccesstest.txt has the rights: rwxr-x---
