Install owncloud from RPM repo ownCloud 9.1.3 (stable)
Mount a NFS share on your server
add local storage on NFS directory
Can see your files in owncloud
Can’t see files in owncloud. I can list my NFS directory with apache user.
Operating system: Centos 7.3
Web server: Apache 2.4.6
Database: MariaDB 5.5
PHP version: 5.4.16
ownCloud version: 9.1.3 (stable)
Where did you install ownCloud from: RPM
Signing status (ownCloud 9.0 and above): all clear
“system”: {
“updatechecker”: false,
“instanceid”: “oc5lqcc57und”,
“trusted_domains”: [
“cloud.geekops.fr”
“datadirectory”: “/data/owncloud/”,
“overwrite.cli.url”: “http://cloud.geekops.fr/owncloud”,
“dbtype”: “mysql”,
“version”: “9.1.3.1”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“maintenance”: false,
“loglevel”: 0,
“memcache.local”: “\OC\Memcache\APC”
Are you using encryption: yes
**Are you using an external user-backend, if yes which one:**no
Browser: Chrome
Operating system: Windows
no error
Exception: {“Message”:“HTTP/1.1 404 File with name Photo could not be located”,“Exception”:“Sabre\DAV\Exception\NotFound”,“Code”:0,“Trace”:“#0 /var/www/html/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(903): OCA\DAV\Connector\Sabre\ObjectTree->getNodeForPath(‘Photo’)\n#1 /var/www/html/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(334): Sabre\DAV\Server->getPropertiesForPath(‘Photo’, Array, 1)\n#2 [internal function]: Sabre\DAV\CorePlugin->httpPropFind(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#3 /var/www/html/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 /var/www/html/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459): Sabre\Event\EventEmitter->emit(‘method:PROPFIND’, Array)\n#5 /var/www/html/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\n#6 /var/www/html/owncloud/apps/dav/appinfo/v1/webdav.php(56): Sabre\DAV\Server->exec()\n#7 /var/www/html/owncloud/remote.php(164): require_once(‘/var/www/html/o…’)\n#8 {main}”,“File”:“/var/www/html/owncloud/apps/dav/lib/Connector/Sabre/ObjectTree.php”,“Line”:170,“User”:“admin”}
