Found workaround.
You can not choose the root folder as a Sync Folder.
Chose the sub dir as sync folder and viola your files are there.
Found workaround.
Sorry for openning old thread, but this workaround only works if there is no subfolders in sub dir you selected to be synced.
As soon as I create a sub folder inside the synced dir and put any files there after resync the become shown as folders.
