After updated to 9.1.6 our users noticed a strange behaviour using webdav. The MS office lock files (~$…) are created as usually once open an office file, but at the same second they are deleted even if the file is open.
We loose the capability to know if another user is editing the file.
Windows 8.1 webdav
CentOS Linux release 7.3.1611
Maria-DB 5.5.52
ownCloud version:
9.1.6.2
updated
owncloud repositories
“system”: {
“theme”: “REMOVED”,
“instanceid”: “oc4nolrr14dg”,
“trusted_domains”: [
“REMOVED”,
“REMOVED”,
“REMOVED”,
“REMOVED”
“datadirectory”: “/home/owncloud/data”,
“overwrite.cli.url”: “http://REMOVED/owncloud”,
“dbtype”: “mysql”,
“version”: “9.1.6.2”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “Europe/Lisbon”,
“installed”: true,
“ldapIgnoreNamingRules”: false,
“loglevel”: 3,
“mail_smtpmode”: “smtp”,
“mail_from_address”: “REMOVED”,
“mail_domain”: “REMOVED”,
“mail_smtphost”: “REMOVED”,
“mail_smtpport”: “25”,
“updatechecker”: false,
“maintenance”: false,
“singleuser”: false,
“forcessl”: true,
“enable_previews”: true,
“preview_libreoffice_path”: “/usr/bin/libreoffice”,
“enabledPreviewProviders”: [
“OC\Preview\Image”,
“OC\Preview\MP3”,
“OC\Preview\TXT”,
“OC\Preview\MarkDown”
“enable_avatars”: true,
“allow_user_to_change_display_name”: false,
“skeletondirectory”: “”,
“lost_password_link”: “REMOVED”,
“trashbin_retention_obligation”: “30,auto”,
“htaccess.RewriteBase”: “/owncloud”,
“quota_include_external_storage”: false,
“versions_retention_obligation”: “auto”,
“filelocking.enabled”: true,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379,
“timeout”: 0,
“password”: “REMOVED SENSITIVE VALUE”
“session_keepalive”: true,
“session_lifetime”: 172800,
“check_for_working_webdav”: true
Enabled:
- activity: 2.3.2
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.2.7
- federatedfilesharing: 0.3.0
- files: 1.5.1
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_texteditor: 2.1
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- firstrunwizard: 1.1
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
- user_ldap: 0.9.0
no
no
Active Directory
| Configuration | |
| hasMemberOfFilterSupport | 1 |
| hasPagedResultSupport | |
| homeFolderNamingRule | attr:sAMAccountName |
| lastJpegPhotoLookup | 0 |
| ldapAgentName | REMOVED |
| ldapAgentPassword | *** |
| ldapAttributesForGroupSearch | |
| ldapAttributesForUserSearch | |
| ldapBackupHost | REMOVED |
| ldapBackupPort | |
| ldapBase | REMOVED |
| ldapBaseGroups | REMOVED |
| ldapBaseUsers | REMOVED |
| ldapCacheTTL | 600 |
| ldapConfigurationActive | 1 |
| ldapDynamicGroupMemberURL | |
| ldapEmailAttribute | mail |
| ldapExperiencedAdmin | 0 |
| ldapExpertUUIDGroupAttr | |
| ldapExpertUUIDUserAttr | |
| ldapExpertUsernameAttr | samaccountname |
| ldapGroupDisplayName | samaccountname |
| ldapGroupFilter | (&(|(objectclass=group))) |
| ldapGroupFilterGroups | |
| ldapGroupFilterMode | 1 |
| ldapGroupFilterObjectclass | |
| ldapGroupMemberAssocAttr | member |
| ldapHost | REMOVED |
| ldapIgnoreNamingRules | |
| ldapLoginFilter | (&(&(|(objectclass=person))(|(|(memberof=CN=Domain Users,CN=Users,REMOVED)(primaryGroupID=513))))(userPrincipalName=%uid)) |
| ldapLoginFilterAttributes | |
| ldapLoginFilterEmail | 0 |
| ldapLoginFilterMode | 1 |
| ldapLoginFilterUsername | 1 |
| ldapNestedGroups | 1 |
| ldapOverrideMainServer | |
| ldapPagingSize | 500 |
| ldapPort | 389 |
| ldapQuotaAttribute | extensionAttribute6 |
| ldapQuotaDefault | 5400000000 |
| ldapTLS | 0 |
| ldapUserDisplayName | displayName |
| ldapUserDisplayName2 | mail |
| ldapUserFilter | (&(|(objectclass=organizationalPerson))(|(|(memberof=CN=Domain Users,REMOVED)(primaryGroupID=513)))) |
| ldapUserFilterGroups | |
| ldapUserFilterMode | 1 |
| ldapUserFilterObjectclass | person |
| ldapUuidGroupAttribute | auto |
| ldapUuidUserAttribute | auto |
| turnOffCertCheck | 1 |
| useMemberOfToDetectMembership | 1 |
