- docker container: owncloud/server:10.8.0 (or earlier Versions)
- another docker container with mysql:5.7
- upload a file > 1 MB
File will be uploaded
Upload stopps with Error Message “Unknown Error “error” while uploading the file “test.log””
Updated
"system": {
"tempdirectory": "\/tmp",
"apps_paths": [
"url": "\/apps",
"writable": false
"path": "\/var\/www\/owncloud\/custom",
"url": "\/custom",
"writable": true
"trusted_domains": [
"localhost"
"datadirectory": "\/mnt\/data\/files",
"dbtype": "mysql",
"dbhost": "Database",
"dbname": "owncloud",
"dbtableprefix": "oc_",
"log_type": "owncloud",
"supportedDatabases": [
"sqlite",
"mysql",
"pgsql"
"upgrade.disable-web": true,
"default_language": "en",
"overwrite.cli.url": "http:\/\/cloud..........de\/",
"htaccess.RewriteBase": "\/",
"logfile": "\/mnt\/data\/files\/owncloud.log",
"loglevel": 0,
"filelocking.enabled": true,
"instanceid": ".........",
"version": "10.8.0.4",
"logtimezone": "UTC",
"installed": true,
"maintenance": false,
"mail_smtpmode": "php",
"mysql.utf8mb4": true
Enabled:
- activity:
- Version: 2.6.1
- dav:
- Version: 0.6.0
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.5.2
- files_external:
- Version: 0.8.0
- files_mediaviewer:
- Version: 1.0.5
- Path: /var/www/owncloud/custom/files_mediaviewer
- files_pdfviewer:
- Version: 0.12.0
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.4.1
- Path: /var/www/owncloud/custom/files_texteditor
- files_trashbin:
- Version: 0.9.1
- firstrunwizard:
- Version: 1.2.0
- market:
- Version: 0.6.0
- notifications:
- Version: 0.5.4
- provisioning_api:
- Version: 0.5.0
- templateeditor:
- Version: 0.4.0
- Path: /var/www/owncloud/apps/templateeditor
- updatenotification:
- Version: 0.2.1
no
no
no
Chrome, Firefox
Windows 10, Windows 11
Where to find?
Nothing.. Not even an PUT.
XHRowncloud.log
/remote.php/dav/files/cloudadmin/Documents
XHRgetstoragestats.php?dir=%2FDocuments
/index.php/apps/files/ajax
XHRnotifications?format=json
/ocs/v2.php/apps/notifications/api/v1
5 Anfragen
3.5 kB übertragen
1.8 kB Ressourcen
URL beantragen: https://cloud..........de/remote.php/dav/files/cloudadmin/Documents/owncloud.log
Anfragemethode: PUT
Statuscode: 413
Remote-Adresse: .......:443
Richtlinien für Verweis-URL: no-referrer
content-length: 585
content-type: text/html
date: Tue, 07 Dec 2021 22:16:11 GMT
server: nginx/1.19.3
strict-transport-security: max-age=31536000
:authority: cloud.......de
:method: PUT
:path: /remote.php/dav/files/cloudadmin/Documents/owncloud.log
:scheme: https
accept: */*
accept-encoding: gzip, deflate, br
accept-language: de
cache-control: no-cache
content-disposition: attachment; filename="owncloud.log"
content-length: 5568437
content-type: application/octet-stream
cookie: oc_sessionPassphrase=.............................
dnt: 1
if-none-match: *
ocs-apirequest: true
origin: https://cloud.einsatzstellenverwaltung.de
pragma: no-cache
requesttoken: .......
sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="96", "Google Chrome";v="96"
sec-ch-ua-mobile: ?0
sec-ch-ua-platform: "Windows"
sec-fetch-dest: empty
sec-fetch-mode: cors
sec-fetch-site: same-origin
user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36
x-oc-mtime: 1638911920.803
x-requested-with: XMLHttpRequest
