10.0.5.4 - Administration panel show only "Cron"
  1. Update to 10.0.5.4
  2. Change some settings like cron (instead of Ajax) and enable file locking
  3. Restart server
  4. Try to go to the GENERAL administration pannel
The administration panel
Empty page with only Cron displayed. Page code is like that (< are [ and > are ]):
[div class=“section” id=“backgroundjobs”]
[h2 class=“app-name has-documentation”>Cron[/h2]
[p class=“cronlog inlineblock”]
And I’ve got an error in Apche2 log specific to that page loading process:
[Wed Jan 24 18:55:16.931955 2018] [:error] [pid 20626] [client 127.0.0.1:35464] PHP Fatal error: Method OC_L10N_String::__toString() must not throw an exception, caught Error: Class ‘Symfony\Component\Translation\PluralizationRules’ not found in /home/www/owncloud/lib/private/L10N/L10N.php on line 0
Operating system: Ubuntu 17.10 (I know you’re not compatible for it but I’ve the same error on 17.4 just before dist-upgrade)
Web server: Apache/2.4.27
Database: mysql Ver 14.14 Distrib 5.7.21
PHP version: PHP 7.1.11
ownCloud version: 10.0.5.4
Updated from an older ownCloud or fresh install: Updated from 9.something (don’t remimber which version)
Where did you install ownCloud from: Official repo for Ubuntu from owncloud docs
Signing status (ownCloud 9.0 and above): No errors have been found.
    "system": {
        "trusted_domains": [
        "forcessl": true,
        "instanceid": "oc7bd28573e8",
        "overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
        "dbtype": "mysql",
        "version": "10.0.5.4",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "installed": true,
        "mail_smtpmode": "php",
        "maintenance": false,
        "loglevel": "2",
        "redis": {
            "host": "localhost",
            "port": 6379
        "enable_previews": true,
        "updatechecker": false,
        "theme": ""
Enabled:
  - activity: 2.3.6
  - announcementcenter: 1.2.0
  - audioplayer: 2.2.4
  - comments: 0.3.0
  - configreport: 0.1.1
  - dav: 0.3.2
  - encryption: 1.3.1
  - federatedfilesharing: 0.3.1
  - files: 1.5.1
  - files_external: 0.7.1
  - files_pdfviewer: 0.8.2
  - files_sharing: 0.10.1
  - files_texteditor: 2.2.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - gallery: 16.0.2
  - market: 0.2.3
  - notifications: 0.3.2
  - polls: 0.8.0
  - provisioning_api: 0.5.0
  - security: 0.0.2
  - systemtags: 0.3.0
  - templateeditor: 0.2
  - updatenotification: 0.2.1
Disabled:
  - external
  - federation
  - theme-example
  - user_external
Are you using external storage, if yes which one: NO
Are you using encryption: yes
Are you using an external user-backend, if yes which one: Can’t see
Browser: Chrome Version 63.0.3239.108
Operating system: Fedora 27
[Wed Jan 24 18:55:16.931955 2018] [:error] [pid 20626] [client 127.0.0.1:35464] PHP Fatal error:  Method OC_L10N_String::__toString() must not throw an exception, caught Error: Class 'Symfony\\Component\\Translation\\PluralizationRules' not found in /home/www/owncloud/lib/private/L10N/L10N.php on line 0
{"reqId":"UesWlGjqEO5YBAqds6nv","level":3,"time":"2018-01-24T18:10:24+00:00","remoteAddr":"127.0.0.1","user":"Tutul","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/settings\/admin?sectionid=general","message":"Method OC_L10N_String::__toString() must not throw an exception, caught Error: Class 'Symfony\\Component\\Translation\\PluralizationRules' not found at \/home\/www\/owncloud\/lib\/private\/L10N\/L10N.php#0"}
Request URL:https://******************/owncloud/index.php/settings/admin?sectionid=general
Request Method:GET
Status Code:500 Internal Server Error
Remote Address:******************:443
Referrer Policy:no-referrer
Hello!
Same Problem her with an empty Page and Cron!
Update from 10.0.4 to 10.0.5.
OS: Ubuntu 16.04
Official repo Ubuntu
I’m seeing the same error on CentOS 6.9 after updating from 10.0.4 to 10.0.5. (OC repo)
Temporary workaround:
As this is a problem with a translation component, you can change your personal language under Settings->Personal->General to “English”
After this change I was able to open the general admin page again.
Hello!
Yes, this works! Thank you for this workaround :grinning:
Works for me too. Thank you! :smiley:
The same problem on debian 9, php7.0, upgrade via apt from 10.0.4 to 10.0.5 language polish, works on English language setting
We will asap release 10.0.6 which will fix this. A new php dependency was missing in the release bundle.
Ok :slight_smile: I’ll be waiting for it ^^
how can you fix this if you can’t even login to owncloud?
How can you use this workaround if you cant login
I am seeing this error on erro_log
[26-Sep-2018 12:53:33 UTC] PHP Fatal error: Class ‘OC_L10N_String’ not found in /***/lib/private/l10n/l10n.php on line 84
if i’m understanding the previously posted messages correctly it seems all you need to do is update to an ownCloud version 10.0.6 or higher.
If you’re already on such a recent version then i think the chances are quite high that you’re stumbling over an issue unrelated to the one discussed here in the past.
