10.0.7 upgrade to 10.0.8 failed
Cliff notes, default install 10.0.7 upgraded from 10.0.8 centos managed packages. Failed. This is why you don’t upgrade the very day a product has been updated :slight_smile:
This forum limits you to 32000 characters and thus I had to trim down the generated config report and put rest of it in the 2nd reply. Thanks for any help!
###here is rest of the generated config report sans apps descriptions
“phpinfo”: {
“apache2handler”: {
“Apache Version”: “Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.0.29”,
“Apache API Version”: “20120211”,
“Server Administrator”: “REMOVED SENSITIVE VALUE”,
“Hostname:Port”: “REMOVED SENSITIVE VALUE:0”,
“User/Group”: “apache(48)/48”,
“Max Requests”: “Per Child: 0 - Keep Alive: on - Max Per Connection: 100”,
“Timeouts”: “Connection: 60 - Keep-Alive: 5”,
“Virtual Server”: “Yes”,
“Server Root”: “/etc/httpd”,
“Loaded Modules”: “core mod_so http_core mod_access_compat mod_actions mod_alias mod_allowmethods mod_auth_basic mod_auth_digest mod_authn_anon mod_authn_core mod_authn_dbd mod_authn_dbm mod_authn_file mod_authn_socache mod_authz_core mod_authz_dbd mod_authz_dbm mod_authz_groupfile mod_authz_host mod_authz_owner mod_authz_user mod_autoindex mod_cache mod_cache_disk mod_data mod_dbd mod_deflate mod_dir mod_dumpio mod_echo mod_env mod_expires mod_ext_filter mod_filter mod_headers mod_include mod_info mod_log_config mod_logio mod_mime_magic mod_mime mod_negotiation mod_remoteip mod_reqtimeout mod_rewrite mod_setenvif mod_slotmem_plain mod_slotmem_shm mod_socache_dbm mod_socache_memcache mod_socache_shmcb mod_status mod_substitute mod_suexec mod_unique_id mod_unixd mod_userdir mod_version mod_vhost_alias mod_dav mod_dav_fs mod_dav_lock mod_lua prefork mod_proxy mod_lbmethod_bybusyness mod_lbmethod_byrequests mod_lbmethod_bytraffic mod_lbmethod_heartbeat mod_proxy_ajp mod_proxy_balancer mod_proxy_connect mod_proxy_express mod_proxy_fcgi mod_proxy_fdpass mod_proxy_ftp mod_proxy_http mod_proxy_scgi mod_proxy_wstunnel mod_ssl mod_systemd mod_cgi mod_php7”,
“engine”: “1”,
“last_modified”: “0”,
“xbithack”: “0”
“Apache Environment”: {
“REDIRECT_UNIQUE_ID”: “WuQAsW-E2nDeGgaLZpz6sAAAAAg”,
“REDIRECT_HTTP_AUTHORIZATION”: “no value”,
“REDIRECT_PATH_INFO”: “no value”,
“REDIRECT_modHeadersAvailable”: “true”,
“REDIRECT_htaccessWorking”: “true”,
“REDIRECT_front_controller_active”: “true”,
“REDIRECT_HTTPS”: “on”,
“REDIRECT_SSL_TLS_SNI”: “REMOVED SENSITIVE VALUE”,
“REDIRECT_STATUS”: “200”,
“UNIQUE_ID”: “WuQAsW-E2nDeGgaLZpz6sAAAAAg”,
“HTTP_AUTHORIZATION”: “no value”,
“PATH_INFO”: “no value”,
“modHeadersAvailable”: “true”,
“htaccessWorking”: “true”,
“front_controller_active”: “true”,
“HTTPS”: “on”,
“SSL_TLS_SNI”: “REMOVED SENSITIVE VALUE”,
“HTTP_ACCEPT”: “text/html, application/xhtml+xml, image/jxr, /”,
“HTTP_ACCEPT_LANGUAGE”: “en-US,en;q=0.5”,
“HTTP_USER_AGENT”: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36 Edge/16.16299”,
“HTTP_ACCEPT_ENCODING”: “gzip, deflate, br”,
“HTTP_HOST”: “REMOVED SENSITIVE VALUE”,
“HTTP_CONNECTION”: “Keep-Alive”,
“SERVER_SIGNATURE”: “no value”,
“SERVER_SOFTWARE”: “Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.0.29”,
“SERVER_NAME”: “REMOVED SENSITIVE VALUE”,
“SERVER_ADDR”: “REMOVED SENSITIVE VALUE”,
“SERVER_PORT”: “443”,
“REMOTE_ADDR”: “REMOVED SENSITIVE VALUE”,
“DOCUMENT_ROOT”: “/var/www/html/”,
“REQUEST_SCHEME”: “https”,
“CONTEXT_PREFIX”: “no value”,
“CONTEXT_DOCUMENT_ROOT”: “/var/www/html/”,
“SERVER_ADMIN”: “REMOVED SENSITIVE VALUE”,
“SCRIPT_FILENAME”: “/var/www/html/owncloud/index.php”,
“REMOTE_PORT”: “51353”,
“REDIRECT_URL”: “/owncloud/apps/configreport/report”,
“GATEWAY_INTERFACE”: “CGI/1.1”,
“SERVER_PROTOCOL”: “HTTP/1.1”,
“REQUEST_METHOD”: “GET”,
“QUERY_STRING”: “no value”,
“REQUEST_URI”: “/owncloud/apps/configreport/report”,
“SCRIPT_NAME”: “/owncloud/index.php”
“HTTP Headers Information”: {
“HTTP Request”: “GET /owncloud/apps/configreport/report HTTP/1.1”,
“Accept”: “text/html, application/xhtml+xml, image/jxr, /”,
“Accept-Language”: “en-US,en;q=0.5”,
“User-Agent”: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36 Edge/16.16299”,
“Accept-Encoding”: “gzip, deflate, br”,
“Host”: “REMOVED SENSITIVE VALUE”,
“Connection”: “Keep-Alive”,
“X-Powered-By”: “PHP/7.0.29”,
“Expires”: “Thu, 19 Nov 1981 08:52:00 GMT”,
“Cache-Control”: “no-store, no-cache, must-revalidate”,
“Pragma”: “no-cache”,
“Content-Security-Policy”: “default-src self ; script-src self unsafe-eval ; style-src self unsafe-inline ; frame-src *; img-src * data: blob:; font-src self data:; media-src *; connect-src *”
“apcu”: {
“APCu Support”: “Enabled”,
“Version”: “5.1.10”,
“APCu Debugging”: “Disabled”,
“MMAP Support”: “Enabled”,
“MMAP File Mask”: “/tmp/apc.40Jiyg”,
“Serialization Support”: “php”,
“Build Date”: “Feb 26 2018 05:29:56”,
“apc.coredump_unmap”: “Off”,
“apc.enable_cli”: “Off”,
“apc.enabled”: “On”,
“apc.entries_hint”: “4096”,
“apc.gc_ttl”: “3600”,
“apc.mmap_file_mask”: “/tmp/apc.40Jiyg”,
“apc.preload_path”: “no value”,
“apc.serializer”: “default”,
“apc.shm_segments”: “1”,
“apc.shm_size”: “64M”,
“apc.slam_defense”: “On”,
“apc.smart”: “0”,
“apc.ttl”: “7200”,
“apc.use_request_time”: “On”,
“apc.writable”: “/tmp”
“bz2”: {
“BZip2 Support”: “Enabled”,
“Stream Wrapper support”: “compress.bzip2://”,
“Stream Filter support”: “bzip2.decompress, bzip2.compress”,
“BZip2 Version”: “1.0.6, 6-Sept-2010”
“calendar”: {
“Calendar support”: “enabled”
“Core”: {
“PHP Version”: “7.0.29”,
“allow_url_fopen”: “On”,
“allow_url_include”: “Off”,
“arg_separator.input”: “&”,
“arg_separator.output”: “&”,
“auto_append_file”: “no value”,
“auto_globals_jit”: “On”,
“auto_prepend_file”: “no value”,
“browscap”: “no value”,
“default_charset”: “UTF-8”,
“default_mimetype”: “text/html”,
“disable_classes”: “no value”,
“disable_functions”: “no value”,
“display_errors”: “Off”,
“display_startup_errors”: “Off”,
“doc_root”: “no value”,
“docref_ext”: “no value”,
“docref_root”: “no value”,
“enable_dl”: “Off”,
“enable_post_data_reading”: “On”,
“error_append_string”: “no value”,
“error_log”: “no value”,
“error_prepend_string”: “no value”,
“error_reporting”: [
“32767”,
“22527”
“exit_on_timeout”: “Off”,
“expose_php”: “On”,
“extension_dir”: “/usr/lib64/php/modules”,
“file_uploads”: “On”,
“highlight.comment”: “#FF8000”,
“highlight.default”: “#0000BB”,
“highlight.html”: “#000000”,
“highlight.keyword”: “#007700”,
“highlight.string”: “#DD0000”,
“html_errors”: “On”,
“ignore_repeated_errors”: “Off”,
“ignore_repeated_source”: “Off”,
“ignore_user_abort”: “Off”,
“implicit_flush”: “Off”,
“input_encoding”: “no value”,
“internal_encoding”: “no value”,
“log_errors”: “On”,
“log_errors_max_len”: “1024”,
“mail.add_x_header”: “On”,
“mail.force_extra_parameters”: “no value”,
“mail.log”: “no value”,
“max_execution_time”: “3600”,
“max_file_uploads”: “20”,
“max_input_nesting_level”: “64”,
“max_input_time”: “3600”,
“max_input_vars”: “1000”,
“memory_limit”: [
“512M”,
“128M”
“open_basedir”: “no value”,
“output_buffering”: [
“0”,
“4096”
“output_encoding”: “no value”,
“output_handler”: “no value”,
“post_max_size”: [
“513M”,
“8M”
“precision”: “14”,
“realpath_cache_size”: “4096K”,
“realpath_cache_ttl”: “120”,
“register_argc_argv”: “Off”,
“report_memleaks”: “On”,
“report_zend_debug”: “On”,
“request_order”: “GP”,
“sendmail_from”: “no value”,
“sendmail_path”: “/usr/sbin/sendmail -t -i”,
“serialize_precision”: “17”,
“short_open_tag”: “Off”,
“SMTP”: “localhost”,
“smtp_port”: “25”,
“sql.safe_mode”: “Off”,
“sys_temp_dir”: “no value”,
“track_errors”: “Off”,
“unserialize_callback_func”: “no value”,
“upload_max_filesize”: [
“513M”,
“2M”
“upload_tmp_dir”: “/synology/tmp”,
“user_dir”: “no value”,
“user_ini.cache_ttl”: “300”,
“user_ini.filename”: “.user.ini”,
“variables_order”: “GPCS”,
“xmlrpc_error_number”: “0”,
“xmlrpc_errors”: “Off”,
“zend.assertions”: “-1”,
“zend.detect_unicode”: “On”,
“zend.enable_gc”: “On”,
“zend.multibyte”: “Off”,
“zend.script_encoding”: “no value”
“ctype”: {
“ctype functions”: “enabled”
“curl”: {
“cURL support”: “enabled”,
“cURL Information”: “7.29.0”,
“Age”: “3”,
“Features”: null,
“AsynchDNS”: “Yes”,
“CharConv”: “No”,
“Debug”: “No”,
“GSS-Negotiate”: “Yes”,
“IDN”: “Yes”,
“IPv6”: “Yes”,
“krb4”: “No”,
“Largefile”: “Yes”,
“libz”: “Yes”,
“NTLM”: “Yes”,
“NTLMWB”: “Yes”,
“SPNEGO”: “No”,
“SSL”: “Yes”,
“SSPI”: “No”,
“TLS-SRP”: “No”,
“Protocols”: “dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtsp, scp, sftp, smtp, smtps, telnet, tftp”,
“Host”: “x86_64-redhat-linux-gnu”,
“SSL Version”: “NSS/3.28.4”,
“ZLib Version”: “1.2.7”,
“libSSH Version”: “libssh2/1.4.3”
“date”: {
“date/time support”: “enabled”,
“timelib version”: “2016.02”,
“"Olson" Timezone Database Version”: “0.system”,
“Timezone Database”: “internal”,
“Default timezone”: “UTC”,
“date.default_latitude”: “31.7667”,
“date.default_longitude”: “35.2333”,
“date.sunrise_zenith”: “90.583333”,
“date.sunset_zenith”: “90.583333”,
“date.timezone”: “no value”
“dom”: {
“DOM/XML”: “enabled”,
“DOM/XML API Version”: “20031129”,
“libxml Version”: “2.9.1”,
“HTML Support”: “enabled”,
“XPath Support”: “enabled”,
“XPointer Support”: “enabled”,
“Schema Support”: “enabled”,
“RelaxNG Support”: “enabled”
“exif”: {
“EXIF Support”: “enabled”,
“EXIF Version”: “7.0.29”,
“Supported EXIF Version”: “0220”,
“Supported filetypes”: “JPEG,TIFF”,
“exif.decode_jis_intel”: “JIS”,
“exif.decode_jis_motorola”: “JIS”,
“exif.decode_unicode_intel”: “UCS-2LE”,
“exif.decode_unicode_motorola”: “UCS-2BE”,
“exif.encode_jis”: “no value”,
“exif.encode_unicode”: “ISO-8859-15”
“fileinfo”: {
“fileinfo support”: “enabled”,
“version”: “1.0.5”,
“libmagic”: “522”
“filter”: {
“Input Validation and Filtering”: “enabled”,
“Revision”: “$Id: 28fcca4bfda9c9907588a64d245b49cb398249d8 $”,
“filter.default”: “unsafe_raw”,
“filter.default_flags”: “no value”
“ftp”: {
“FTP support”: “enabled”,
“FTPS support”: “enabled”
“gd”: {
“GD Support”: “enabled”,
“GD Version”: “bundled (2.1.0 compatible)”,
“FreeType Support”: “enabled”,
“FreeType Linkage”: “with freetype”,
“FreeType Version”: “2.4.11”,
“GIF Read Support”: “enabled”,
“GIF Create Support”: “enabled”,
“JPEG Support”: “enabled”,
“libJPEG Version”: “6b”,
“PNG Support”: “enabled”,
“libPNG Version”: “1.5.13”,
“WBMP Support”: “enabled”,
“XPM Support”: “enabled”,
“libXpm Version”: “30411”,
“XBM Support”: “enabled”,
“gd.jpeg_ignore_warning”: [
“1”,
“0”
“gettext”: {
“GetText Support”: “enabled”
“gmp”: {
“gmp support”: “enabled”,
“GMP version”: “6.0.0”
“hash”: {
“hash support”: “enabled”,
“Hashing Engines”: “md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5”,
“MHASH support”: “Enabled”,
“MHASH API Version”: “Emulated Support”
“iconv”: {
“iconv support”: “enabled”,
“iconv implementation”: “glibc”,
“iconv library version”: “2.17”,
“iconv.input_encoding”: “no value”,
“iconv.internal_encoding”: “no value”,
“iconv.output_encoding”: “no value”
“intl”: {
“version”: “1.1.0”,
“ICU version”: “50.1.2”,
“ICU Data version”: “50.1”,
“intl.default_locale”: “no value”,
“intl.error_level”: “0”,
“intl.use_exceptions”: “0”
“json”: {
“json support”: “enabled”,
“json version”: “1.4.0”
“ldap”: {
“LDAP Support”: “enabled”,
“RCS Version”: “$Id: cec20da3ccaa477662b8667bef021291fb5bf6f4 $”,
“Total Links”: “0/unlimited”,
“API Version”: “3001”,
“Vendor Name”: “OpenLDAP”,
“Vendor Version”: “20444”,
“SASL Support”: “Enabled”,
“ldap.max_links”: “Unlimited”
“libxml”: {
“libXML support”: “active”,
“libXML Compiled Version”: “2.9.1”,
“libXML Loaded Version”: “20901”,
“libXML streams”: “enabled”
“mbstring”: {
“Multibyte Support”: “enabled”,
“Multibyte string engine”: “libmbfl”,
“HTTP input encoding translation”: “disabled”,
“libmbfl version”: “1.3.2”,
“oniguruma version”: “5.9.6”,
“Multibyte (japanese) regex support”: “enabled”,
“Multibyte regex (oniguruma) backtrack check”: “On”,
“Multibyte regex (oniguruma) version”: “5.9.6”,
“mbstring.detect_order”: “no value”,
“mbstring.encoding_translation”: “Off”,
“mbstring.func_overload”: “0”,
“mbstring.http_input”: “no value”,
“mbstring.http_output”: “no value”,
“mbstring.http_output_conv_mimetypes”: “^(text/|application/xhtml\+xml)”,
“mbstring.internal_encoding”: “no value”,
“mbstring.language”: “neutral”,
“mbstring.strict_detection”: “Off”,
“mbstring.substitute_character”: “no value”
“mysqli”: {
“Client API library version”: “5.5.56-MariaDB”,
“Active Persistent Links”: “0”,
“Inactive Persistent Links”: “0”,
“Active Links”: “0”,
“Client API header version”: “5.5.56-MariaDB”,
“MYSQLI_SOCKET”: “/var/lib/mysql/mysql.sock”,
“mysqli.allow_local_infile”: “On”,
“mysqli.allow_persistent”: “On”,
“mysqli.default_host”: “no value”,
“mysqli.default_port”: “3306”,
“mysqli.default_pw”: “no value”,
“mysqli.default_socket”: “no value”,
“mysqli.default_user”: “no value”,
“mysqli.max_links”: “Unlimited”,
“mysqli.max_persistent”: “Unlimited”,
“mysqli.reconnect”: “Off”,
“mysqli.rollback_on_cached_plink”: “Off”
“openssl”: {
“OpenSSL support”: “enabled”,
“OpenSSL Library Version”: “OpenSSL 1.0.2k-fips 26 Jan 2017”,
“OpenSSL Header Version”: “OpenSSL 1.0.2k-fips 26 Jan 2017”,
“Openssl default config”: “/etc/pki/tls/openssl.cnf”,
“openssl.cafile”: “no value”,
“openssl.capath”: “no value”
“pcre”: {
“PCRE (Perl Compatible Regular Expressions) Support”: “enabled”,
“PCRE Library Version”: “8.38 2015-11-23”,
“PCRE JIT Support”: “enabled”,
“pcre.backtrack_limit”: “1000000”,
“pcre.jit”: “1”,
“pcre.recursion_limit”: “100000”
“PDO”: {
“PDO drivers”: “mysql, sqlite”
“pdo_mysql”: {
“Client API version”: “5.5.56-MariaDB”,
“pdo_mysql.default_socket”: “/var/lib/mysql/mysql.sock”
“pdo_sqlite”: {
“SQLite Library”: “3.7.17”
“Phar”: {
“Phar EXT version”: “2.0.2”,
“Phar API version”: “1.1.1”,
“SVN revision”: “$Id: 9d91fd26ae99260111b934cc25174387d4bd7059 $”,
“Phar-based phar archives”: “enabled”,
“Tar-based phar archives”: “enabled”,
“ZIP-based phar archives”: “enabled”,
“gzip compression”: “enabled”,
“bzip2 compression”: “enabled”,
“Native OpenSSL support”: “enabled”,
“Phar based on pear/PHP_Archive, original concept by Davey Shafik.Phar fully realized by Gregory Beaver and Marcus Boerger.Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.”: null,
“phar.cache_list”: “no value”,
“phar.readonly”: “On”,
“phar.require_hash”: “On”
“posix”: {
“Revision”: “$Id: b691ca925e7a085e6929579c4eba8fed0732e0ef $”
“redis”: {
“Redis Version”: “3.1.6”,
“Available serializers”: “php”
“Reflection”: {
“Version”: “$Id: e5303663dcb329e17818853ff223e5ee01481f2c $”
“session”: {
“Session Support”: “enabled”,
“Registered save handlers”: “files user redis rediscluster”,
“Registered serializer handlers”: “php_serialize php php_binary wddx”,
“session.auto_start”: “Off”,
“session.cache_expire”: “180”,
“session.cache_limiter”: “nocache”,
“session.cookie_domain”: “no value”,
“session.cookie_httponly”: [
“On”,
“Off”
“session.cookie_lifetime”: “0”,
“session.cookie_path”: [
“/owncloud”,
“session.cookie_secure”: [
“On”,
“Off”
“session.entropy_file”: “/dev/urandom”,
“session.entropy_length”: “32”,
“session.gc_divisor”: “1000”,
“session.gc_maxlifetime”: “1440”,
“session.gc_probability”: “1”,
“session.hash_bits_per_character”: “5”,
“session.hash_function”: “0”,
“session.lazy_write”: “On”,
“session.name”: [
“oc08fb282a4a”,
“PHPSESSID”
“session.referer_check”: “no value”,
“session.save_handler”: “files”,
“session.save_path”: [
“/var/lib/php/session”,
“no value”
“session.serialize_handler”: “php”,
“session.upload_progress.cleanup”: “On”,
“session.upload_progress.enabled”: “On”,
“session.upload_progress.freq”: “1%”,
“session.upload_progress.min_freq”: “1”,
“session.upload_progress.name”: “PHP_SESSION_UPLOAD_PROGRESS”,
“session.upload_progress.prefix”: “upload_progress_”,
“session.use_cookies”: “On”,
“session.use_only_cookies”: “On”,
“session.use_strict_mode”: “Off”,
“session.use_trans_sid”: “0”
“shmop”: {
“shmop support”: “enabled”
“SimpleXML”: {
“Revision”: “$Id: 0637e06af859ca1d0dea9c2f1530e51b98f1970e $”,
“Schema support”: “enabled”
“sockets”: {
“Sockets Support”: “enabled”
“SPL”: {
“Interfaces”: “Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject”,
“Classes”: “AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException”
“sqlite3”: {
“SQLite3 module version”: “7.0.29”,
“SQLite Library”: “3.7.17”,
“sqlite3.extension_dir”: “no value”
“standard”: {
“Dynamic Library Support”: “enabled”,
“Path to sendmail”: “/usr/sbin/sendmail -t -i”,
“assert.active”: “1”,
“assert.bail”: “0”,
“assert.callback”: “no value”,
“assert.exception”: “0”,
“assert.quiet_eval”: “0”,
“assert.warning”: “1”,
“auto_detect_line_endings”: “0”,
“default_socket_timeout”: “60”,
“from”: “no value”,
“url_rewriter.tags”: “a=href,area=href,frame=src,input=src,form=fakeentry”,
“user_agent”: “no value”
“sysvmsg”: {
“sysvmsg support”: “enabled”,
“Revision”: “$Id: dfb999763f95bfe9609fae60b4e07a492888ec7c $”
“sysvsem”: {
“Version”: “7.0.29”
“sysvshm”: {
“Version”: “7.0.29”
“tokenizer”: {
“Tokenizer Support”: “enabled”
“wddx”: {
“WDDX Session Serializer”: “enabled”
“xml”: {
“XML Support”: “active”,
“XML Namespace Support”: “active”,
“libxml2 Version”: “2.9.1”
“xmlreader”: {
“XMLReader”: “enabled”
“xmlwriter”: {
“XMLWriter”: “enabled”
“xsl”: {
“XSL”: “enabled”,
“libxslt Version”: “1.1.28”,
“libxslt compiled against libxml Version”: “2.9.1”,
“EXSLT”: “enabled”,
“libexslt Version”: “1.1.28”
“zip”: {
“Zip”: “enabled”,
“Zip version”: “1.13.5”,
“Libzip version”: “1.1.2”
“zlib”: {
“Stream Wrapper”: “compress.zlib://”,
“Stream Filter”: “zlib.inflate, zlib.deflate”,
“Compiled Version”: “1.2.7”,
“Linked Version”: “1.2.7”,
“zlib.output_compression”: “Off”,
“zlib.output_compression_level”: “-1”,
“zlib.output_handler”: “no value”
“Environment”: {
“LANG”: “C”,
“NOTIFY_SOCKET”: “/run/systemd/notify”,
“NSS_STRICT_NOFORK”: “DISABLED”
To me it looks like the following part is exactly providing the required steps to continue with the update:
Thanks but when I log into the owncloud 10.0.7 as an admin and click on Market, there are no updates available.
Why does 10.0.8 fail to fetch the new apps if they already exist in the marketplace. I’ve updated owncloud from 10.0 and have never encountered this app problem.
Since 10.0.8 is so new, I hope some others who have had success updating to 10.0.8 will log on and post some help.
I would suggest to follow the steps above and disable the template editor app before doing the update like the message is suggestion. I think then the update should continue and you can have a look for an update of the app afterwards.
Looks like some other folks are having issues.
This is the last time I update on a new release. I’ll wait until the kinks are worked out.
This looks to me that this is an ongoing issue if people can’t interpret the pointers the upgrading message is giving them. Maybe the message is not that clear?
I just found a explanation of @DeepDiver1975 in Why does updating NEVER work for my owncloud? · Issue #31130 · owncloud/core · GitHub why this is expected and why do you need to interact manually:
Disabling apps can seriously break your instance during Upgrade. Therefore we leave this to the user who can better judge about the Situation.
Why the Upgrade is not working: i assume the apps folder is not writable by the web server
at the bottom of Why does updating NEVER work for my owncloud? · Issue #31130 · owncloud/core · GitHub
he still has issues that disabling apps did not resolve. The link above is not for 10.0.8 but a different version. This is more than just disable/enable apps problem.
Also, in my case there are no permission issues with not being able to write to /apps. During all the upgrades from 10.0 to 10.0.8 there were no app permission problems.
Where is the Administrator guide for 10.0.8? It has not been published on the website yet.
Hopefully they will get this fixed in the next few weeks. Not usable as of now.
On the bottom of update to 10.0.8 failed, the server not accessible · Issue #31300 · owncloud/core · GitHub the other user had luck by disabling the app as asked in the message so you could try your luck with that as well.
Disabling templateeditor did allow the upgrade. Thanks Tom!
Hi!
I tried to upgrade my owncloud server from 10.0.7 to 10.0.8 via the upgrade button and. The upgrade failed (frozen maintenance mode screen). I then used occ on the command line (webserver user _www on my system to keep the privileges), alas no success either. There seems to be a problem with the mysql database but I’m lost here as I don’t know what the error message means or what I can do about it.
Here’s what the shell says:
hmegies:owncloud holger$ sudo -u _www php occ upgrade
Password:
2018-05-07T13:21:19+00:00 Set log level to debug
2018-05-07T13:21:19+00:00 Repair step: Repair MySQL database engine
2018-05-07T13:21:19+00:00 Repair step: Repair MySQL collation
2018-05-07T13:21:19+00:00 Repair info: All tables already have the correct collation → nothing to do
2018-05-07T13:21:19+00:00 Repair step: Repair SQLite autoincrement
2018-05-07T13:21:19+00:00 Repair step: Repair orphaned reshare
2018-05-07T13:21:19+00:00 Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘DELETE FROM oc_share WHERE parent NOT IN (SELECT id FROM (SELECT id FROM oc_share ORDER BY id ASC) mysqlerr1093hack)’:
SQLSTATE[HY000]: General error: 1093 You can’t specify target table ‘oc_share’ for update in FROM clause
2018-05-07T13:21:19+00:00 Update failed
2018-05-07T13:21:19+00:00 Maintenance mode is kept active
2018-05-07T13:21:19+00:00 Reset log level
I hope someone can help. Thanks in advance!
can you try to execute this command again with “-vvv” at the end for verbose otuput?
Also, what Database are you using?
I think this is a completely different issue which should be discussed in a separate thread to avoid mixing two problems.
I agree. This seems to be a database issue.
Thank you dmitry and tom for your replies. I suspected it was a database issue… Can you move this discussion to a thread that fits?
Unfortunately the -vvv option doesn’t make much of a difference:
2018-05-07T14:20:12+00:00 Set log level to debug
2018-05-07T14:20:12+00:00 Repair step: Repair MySQL database engine
2018-05-07T14:20:12+00:00 Repair step: Repair MySQL collation
2018-05-07T14:20:12+00:00 Repair info: All tables already have the correct collation → nothing to do
2018-05-07T14:20:12+00:00 Repair step: Repair SQLite autoincrement
2018-05-07T14:20:12+00:00 Repair step: Repair orphaned reshare
2018-05-07T14:20:12+00:00 Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘DELETE FROM oc_share WHERE parent NOT IN (SELECT id FROM (SELECT id FROM oc_share ORDER BY id ASC) mysqlerr1093hack)’:
2018-05-07T14:20:12+00:00 Update failed
2018-05-07T14:20:12+00:00 Maintenance mode is kept active
2018-05-07T14:20:12+00:00 Reset log level
I’m using mysql 5.7.10 on a MacMini running OSX 10.9
I can’t move this.
It would be best if you just open a new thread with detailed description ( as much as you can ) of your problem and your setup
