Dear all,
I face the following error message, and after spending days on Github and forums, I am stuck.
When trying to update 8.1.6 to 8.1.9, I get an error message concerning oc_appconfig in the database.
What I checked and did …
- MySQL not corrupt
- Owncloud user has all rights to owncloud DB
- last DB Backup successfully restored
- sudo -u www-data php occ maintenance:repair
- 3-months-old backup of owncloud and the mysql database recovered (at time of backup in April, owncloud was just running perfectly smoothly and stable and there had been no updates downloaded or initiated)
- no duplicate entries in database tables or other various stuff reported with similar issues on Github
- download and extract owncloud 8.1.9 file from owncloud repos
- copy all files to /var/www/owncloud
- chown root:root /var/www/owncloud/occrights.sh && chmod u+x /var/www/owncloud/occrights.sh && sh /var/www/owncloud/occrights.sh
- sudo -u www-data php /var/www/owncloud/occ upgrade or sudo -u www-data php /var/www/owncloud/occ upgrade --skip-migration-test
Upgrade should proceed and finish.
Error message …
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘ALTER TABLE oc_appconfig DROP PRIMARY KEY’:
SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘PRIMARY’; check that column/key exists
Update failed
Operating system: Ubuntu 14.04.1
Web server: apache2
Database: Mysql 5.5.50
PHP version: 5.6
ownCloud version (see ownCloud admin page): 8.1.6
Updated from an older ownCloud or fresh install: so far, continuously updated since v6 via SUSE repos /repositories/isv:/ownCloud:/community/xUbuntu_14.04 - openSUSE Download
ownCloud log:
{"reqId":"jPKaRZr0kFDLNWqHQydo","remoteAddr":"","app":"PHP","message":"file_put_contents(\/var\/www\/owncloud\/data\/.htaccess): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/setup.php#435","level":3,"time":"2016-07-24T12:19:26+00:00","method":"--","url":"--"} {"reqId":"jPKaRZr0kFDLNWqHQydo","remoteAddr":"","app":"core","message":"Failed to update database structure (exception 'PDOException' with message 'SQLSTATE[42000]: Syntax error or access violation: 1091 Can't DROP 'PRIMARY'; check that column\/key exists' in \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php:104\nStack trace:\n#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php(104): PDO->query('ALTER TABLE oc_...')\n#1 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(935): Doctrine\\DBAL\\Driver\\PDOConnection->query('ALTER TABLE oc_...')\n#2 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(219): Doctrine\\DBAL\\Connection->query('ALTER TABLE oc_...')\n#3 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(69): OC\\DB\\Migrator->applySchema(Object(Doctrine\\DBAL\\Schema\\Schema))\n#4 \/var\/www\/owncloud\/lib\/private\/db\/mdb2schemamanager.php(121): OC\\DB\\Migrator->migrate(Object(Doctrine\\DBAL\\Schema\\Schema))\n#5 \/var\/www\/owncloud\/lib\/private\/db.php(231): OC\\DB\\MDB2SchemaManager->updateDbFromStructure('\/var\/www\/ownclo...')\n#6 \/var\/www\/owncloud\/lib\/private\/updater.php(354): OC_DB::updateDbFromStructure('\/var\/www\/ownclo...')\n#7 \/var\/www\/owncloud\/lib\/private\/updater.php(322): OC\\Updater->doCoreUpgrade()\n#8 \/var\/www\/owncloud\/lib\/private\/updater.php(205): OC\\Updater->doUpgrade('8.1.9.2', '8.1.6.2')\n#9 \/var\/www\/owncloud\/core\/command\/upgrade.php(187): OC\\Updater->upgrade()\n#10 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Command\/Command.php(253): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#11 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(874): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#12 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(195): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#13 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(126): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#14 \/var\/www\/owncloud\/lib\/private\/console\/application.php(96): Symfony\\Component\\Console\\Application->run(NULL, NULL)\n#15 \/var\/www\/owncloud\/console.php(68): OC\\Console\\Application->run()\n#16 \/var\/www\/owncloud\/occ(11): require_once('\/var\/www\/ownclo...')\n#17 {main}\n\nNext exception 'Doctrine\\DBAL\\Driver\\PDOException' with message 'SQLSTATE[42000]: Syntax error or access violation: 1091 Can't DROP 'PRIMARY'; check that column\/key exists' in \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php:106\nStack trace:\n#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(935): Doctrine\\DBAL\\Driver\\PDOConnection->query('ALTER TABLE oc_...')\n#1 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(219): Doctrine\\DBAL\\Connection->query('ALTER TABLE oc_...')\n#2 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(69): OC\\DB\\Migrator->applySchema(Object(Doctrine\\DBAL\\Schema\\Schema))\n#3 \/var\/www\/owncloud\/lib\/private\/db\/mdb2schemamanager.php(121): OC\\DB\\Migrator->migrate(Object(Doctrine\\DBAL\\Schema\\Schema))\n#4 \/var\/www\/owncloud\/lib\/private\/db.php(231): OC\\DB\\MDB2SchemaManager->updateDbFromStructure('\/var\/www\/ownclo...')\n#5 \/var\/www\/owncloud\/lib\/private\/updater.php(354): OC_DB::updateDbFromStructure('\/var\/www\/ownclo...')\n#6 \/var\/www\/owncloud\/lib\/ private\/updater.php(322): OC\\Updater->doCoreUpgrade()\n#7 \/var\/www\/owncloud\/lib\/private\/updater.php(205): OC\\Updater->doUpgrade('8.1.9.2', '8.1.6.2')\n#8 \/var\/www\/owncloud\/core\/command\/upgrade.php(187): OC\\Updater->upgrade()\n#9 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Command\/Command.php(253): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#10 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(874): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#11 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(195): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#12 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(126): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#13 \/var\/www\/owncloud\/lib\/private\/console\/application.php(96): Symfony\\Component\\Console\\Application->run(NULL, NULL)\n#14 \/var\/www\/owncloud\/console.php(68): OC\\Console\\Application->run()\n#15 \/var\/www\/owncloud\/occ(11): require_once('\/var\/www\/ownclo...')\n#16 {main}\n\nNext exception 'Doctrine\\DBAL\\Exception\\DriverException' with message 'An exception occurred while executing 'ALTER TABLE oc_appconfig DROP PRIMARY KEY':\n\nSQLSTATE[42000]: Syntax error or access violation: 1091 Can't DROP 'PRIMARY'; check that column\/key exists' in \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php:115\nStack trace:\n#0 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php(945): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'ALTER TABLE oc_...')\n#2 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(219): Doctrine\\DBAL\\Connection->query('ALTER TABLE oc_...')\n#3 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(69): OC\\DB\\Migrator->applySchema(Object(Doctrine\\DBAL\\Schema\\Schema))\n#4 \/var\/www\/owncloud\/lib\/private\/db\/mdb2schemamanager.php(121): OC\\DB\\Migrator->migrate(Object(Doctrine\\DBAL\\Schema\\Schema))\n#5 \/var\/www\/owncloud\/lib\/private\/db.php(231): OC\\DB\\MDB2SchemaManager->updateDbFromStructure('\/var\/www\/ownclo...')\n#6 \/var\/www\/owncloud\/lib\/private\/updater.php(354): OC_DB::updateDbFromStructure('\/var\/www\/ownclo...')\n#7 \/var\/www\/owncloud\/lib\/private\/updater.php(322): OC\\Updater->doCoreUpgrade()\n#8 \/var\/www\/owncloud\/lib\/private\/updater.php(205): OC\\Updater->doUpgrade('8.1.9.2', '8.1.6.2')\n#9 \/var\/www\/owncloud\/core\/command\/upgrade.php(187): OC\\Updater->upgrade()\n#10 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Command\/Command.php(253): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#11 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(874): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#12 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(195): Symfony\\Component\ \Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#13 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(126): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#14 \/var\/www\/owncloud\/lib\/private\/console\/application.php(96): Symfony\\Component\\Console\\Application->run(NULL, NULL)\n#15 \/var\/www\/owncloud\/console.php(68): OC\\Console\\Application->run()\n#16 \/var\/www\/owncloud\/occ(11): require_once('\/var\/www\/ownclo...')\n#17 {main})","level":4,"time":"2016-07-24T12:19:28+00:00","method":"--","url":"--"} {"reqId":"jPKaRZr0kFDLNWqHQydo","remoteAddr":"","app":"update","message":"Exception: {\"Exception\":\"Doctrine\\\\DBAL\\\\Exception\\\\DriverException\",\"Message\":\"An exception occurred while executing 'ALTER TABLE oc_appconfig DROP PRIMARY KEY':\\n\\nSQLSTATE[42000]: Syntax error or access violation: 1091 Can't DROP 'PRIMARY'; check that column\\\/key exists\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/DBALException.php(116): Doctrine\\\\DBAL\\\\Driver\\\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOException))\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(945): Doctrine\\\\DBAL\\\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOMySql\\\\Driver), Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOException), 'ALTER TABLE oc_...')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db\\\/migrator.php(219): Doctrine\\\\DBAL\\\\Connection->query('ALTER TABLE oc_...')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db\\\/migrator.php(69): OC\\\\DB\\\\Migrator->applySchema(Object(Doctrine\\\\DBAL\\\\Schema\\\\Schema))\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db\\\/mdb2schemamanager.php(121): OC\\\\DB\\\\Migrator->migrate(Object(Doctrine\\\\DBAL\\\\Schema\\\\Schema))\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db.php(231): OC\\\\DB\\\\MDB2SchemaManager->updateDbFromStructure('\\\/var\\\/www\\\/ownclo...')\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/updater.php(354): OC_DB::updateDbFromStructure('\\\/var\\\/www\\\/ownclo...')\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/updater.php(322): OC\\\\Updater->doCoreUpgrade()\\n#8 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/updater.php(205): OC\\\\Updater->doUpgrade('8.1.9.2', '8.1.6.2')\\n#9 \\\/var\\\/www\\\/owncloud\\\/core\\\/command\\\/upgrade.php(187): OC\\\\Updater->upgrade()\\n#10 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Command\\\/Command.php(253): OC\\\\Core\\\\Command\\\\Upgrade->execute(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#11 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Application.php(874): Symfony\\\\Component\\\\Console\\\\Command\\\\Command->run(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#12 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Application.php(195): Symfony\\\\Component\\\\Console\\\\Application->doRunCommand(Object(OC\\\\Core\\\\Command\\\\Upgrade), Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#13 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Application.php(126): Symfony\\\\Component\\\\Console\\\\Application->doRun(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/console\\\/application.php(96): Symfony\\\\Component\\\\Console\\\\Application->run(NULL, NULL)\\n#15 \\\/var\\\/www\\\/owncloud\\\/console.php(68): OC\\\\Console\\\\Application->run()\\n#16 \\\/var\\\/www\\\/owncloud\\\/occ(11): require_once('\\\/var\\\/www\\\/ownclo...')\\n#17 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Driver\\\/AbstractMySQLDriver.php\",\"Line\":115}","level":4,"time":"2016-07-24T12:19:28+00:00","method":"--","url":"--"} {"reqId":"TA26ie4BJYFJNjvjY7pm","remoteAddr":"","app":"PHP","message":"file_put_contents(\/var\/www\/owncloud\/data\/.htaccess): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/setup.php#435","level":3,"time":"2016-07-24T12:23:29+00:00","method":"--","url":"--"} {"reqId":"TA26ie4BJYFJNjvjY7pm","remoteAddr":"","app":"core","message":"Simulated database structure update failed (exception 'OC\\DB\\MigrationException' with message 'An exception occurred while executing 'ALTER TABLE oc_oc_appconfig_rs8xe82z444ua DROP PRIMARY KEY':\n\nSQLSTATE[42000]: Syntax error or access violation: 1091 Can't DROP 'PRIMARY'; check that column\/key exists' in \/var\/www\/owncloud\/lib\/private\/db\/migrator.php:152\nStack trace:\n#0 \/var\/www\/owncloud\/lib\/private\/db\/migrator.php(110): OC\\DB\\Migrator->checkTableMigrate(Object(Doctrine\\DBAL\\Schema\\Table))\n#1 \/var\/www\/owncloud\/lib\/private\/db\/mdb2schemamanager.php(133): OC\\DB\\Migrator->checkMigrate(Object(Doctrine\\DBAL\\Schema\\Schema))\n#2 \/var\/www\/owncloud\/lib\/private\/db.php(248): OC\\DB\\MDB2SchemaManager->simulateUpdateDbFromStructure('\/var\/www\/ownclo...')\n#3 \/var\/www\/owncloud\/lib\/private\/updater.php(347): OC_DB::simulateUpdateDbFromStructure('\/var\/www\/ownclo...')\n#4 \/var\/www\/owncloud\/lib\/private\/updater.php(314): OC\\Updater->checkCoreUpgrade()\n#5 \/var\/www\/owncloud\/lib\/private\/updater.php(205): OC\\Updater->doUpgrade('8.1.9.2', '8.1.6.2')\n#6 \/var\/www\/owncloud\/core\/command\/upgrade.php(187): OC\\Updater->upgrade()\n#7 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Command\/Command.php(253): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#8 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(874): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#9 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(195): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#10 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(126): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#11 \/var\/www\/owncloud\/lib\/private\/console\/application.php(96): Symfony\\Component\\Console\\Application->run(NULL, NULL)\n#12 \/var\/www\/owncloud\/console.php(68): OC\\Console\\Application->run()\n#13 \/var\/www\/owncloud\/occ(11): require_once('\/var\/www\/ownclo...')\n#14 {main})","level":4,"time":"2016-07-24T12:23:31+00:00","method":"--","url":"--"} {"reqId":"TA26ie4BJYFJNjvjY7pm","remoteAddr":"","app":"update","message":"Exception: {\"Exception\":\"OC\\\\DB\\\\MigrationException\",\"Message\":\"An exception occurred while executing 'ALTER TABLE oc_oc_appconfig_rs8xe82z444ua DROP PRIMARY KEY':\\n\\nSQLSTATE[42000]: Syntax error or access violation: 1091 Can't DROP 'PRIMARY'; check that column\\\/key exists\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db\\\/migrator.php(110): OC\\\\DB\\\\Migrator->checkTableMigrate(Object(Doctrine\\\\DBAL\\\\Schema\\\\Table))\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db\\\/mdb2schemamanager.php(133): OC\\\\DB\\\\Migrator->checkMigrate(Object(Doctrine\\\\DBAL\\\\Schema\\\\Schema))\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db.php(248): OC\\\\DB\\\\MDB2SchemaManager->simulateUpdateDbFromStructure('\\\/var\\\/www\\\/ownclo...')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/updater.php(347): OC_DB::simulateUpdateDbFromStructure('\\\/var\\\/www\\\/ownclo...')\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/updater.php(314): OC\\\\Updater->checkCoreUpgrade()\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/updater.php(205): OC\\\\Updater->doUpgrade('8.1.9.2', '8.1.6.2')\\n#6 \\\/var\\\/www\\\/owncloud\\\/core\\\/command\\\/upgrade.php(187): OC\\\\Updater->upgrade()\\n#7 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Command\\\/Command.php(253): OC\\\\Core\\\\Command\\\\Upgrade->execute(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#8 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Application.php(874): Symfony\\\\Component\\\\Console\\\\Command\\\\Command->run(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#9 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Application.php(195): Symfony\\\\Component\\\\Console\\\\Application->doRunCommand(Object(OC\\\\Core\\\\Command\\\\Upgrade), Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#10 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/symfony\\\/console\\\/Symfony\\\/Component\\\/Console\\\/Application.php(126): Symfony\\\\Component\\\\Console\\\\Application->doRun(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#11 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/console\\\/application.php(96): Symfony\\\\Component\\\\Console\\\\Application->run(NULL, NULL)\\n#12 \\\/var\\\/www\\\/owncloud\\\/console.php(68): OC\\\\Console\\\\Application->run()\\n#13 \\\/var\\\/www\\\/owncloud\\\/occ(11): require_once('\\\/var\\\/www\\\/ownclo...')\\n#14 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/db\\\/migrator.php\",\"Line\":152}","level":4,"time":"2016-07-24T12:23:31+00:00","method":"--","url":"--"} {"reqId":"q3Q7yNkRhNZ5TF9Hzfuf","remoteAddr":"192.168.1.22","app":"index","message":"Exception: {\"Exception\":\"OC\\\\NeedsUpdateException\",\"Message\":\"\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/app.php(98): OC_App::loadApp('files')\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/util.php(127): OC_App::loadApps(Array)\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/base.php(876): OC_Util::setupFS()\\n#3 \\\/var\\\/www\\\/owncloud\\\/index.php(48): OC::handleRequest()\\n#4 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/app.php\",\"Line\":118}","level":4,"time":"2016-07-24T12:39:53+00:00"}
config.php:
<?php $CONFIG = array ( 'instanceid' => 'oc3a41047555', 'passwordsalt' => '3ee12637fa36136a5e3cbe60433a1f', 'datadirectory' => '/var/www/owncloud/data', 'dbtype' => 'mysql', 'dbname' => 'ownclouddb', 'dbuser' => 'owncloudusr', 'dbpassword' => 'owncloudpwd', 'dbhost' => 'localhost', 'version' => '8.1.6.2', 'installed' => true, 'forcessl' => true, 'theme' => '', 'maintenance' => false, 'trusted_domains' => array ( 0 => '192.168.1.1', 1 => 'localhost', 2 => 'home.hyomain.de', ), 'forceSSLforSubdomains' => true, 'appcodechecker' => false, 'xframe_restriction' => false, 'cache_path' => '', 'quota_include_external_storage' => false, 'filesystem_check_changes' => 0, 'appstore.experimental.enabled' => false, 'updatechecker' => false, );
Any ideas would be greatly appreciated.
Best
Chris
