32-Bit ARM images missing from dockerhub in version 10.5.0
docker run owncloud/server:latest (which retrieves 10.5.0 currently) yields an error when run on a 32-bit ARM system:
latest: Pulling from owncloud/server
docker: no matching manifest for linux/arm/v7 in the manifest list entries.
Docker should pull down a 32-bit arm image, as has been the case through 10.4.1.
Error above
Operating system: Raspbian
Web server: packaged with the official docker image
Database: webhippie/mariadb:latest
PHP version: packaged with the official docker image
ownCloud version: 10.4.1 (since that’s the latest that works)
Updated from an older ownCloud or fresh install: Attempting to upgrade from 10.4.1–> 10.5
Where did you install ownCloud from: Narnia
Signing status (ownCloud 9.0 and above): ?
“No errors have been found.”
This would be great to have - I don’t really understand what the issue is? I have PHP 7.4 running fine on the same Raspberry Pi so that can’t be the problem…
In the owncloud-docker/server repo I found the following commit:
Which references a bug in Ubuntu: https://bugs.launchpad.net/ubuntu/+source/glibc/+bug/1867675
If you see a workaround, perhaps open a github issue in this repo.
Hmmm sounds like it’ll be a while for a fix. Far beyond my abilities to help I’m afraid. Pondering installing a 64-bit OS on my pi just to get 10.5! Feels a bit drastic though.
